Question about Craftsman 25cc Gas Line Trimmer
Stalls when giving gas
Warms up and running for 15 min and then dies
  • 420 Answers
This symptom is usually lack of fuel to the engine, if you see bubbles in the fuel line replace all of the lines and the fuel filter (inside the tank). If there are no bubbles in the fuel lines the carburetor needs to be cleaned out or replaced.
Posted on May 27, 2010
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
Starts right up but once it warms up it dies have messed with the air gas screws that's fine don't know what the problem is
My car runs good when it's cold but stalls once it warms up ...
www.badasscars.com/index.cfm/page/ptype...id.../prd289.htm
My car runs good when it's cold but stalls once it warms up? ... In this situation, you can usually re-start the engine once it has hada chance to cool back ... it'll fill-up and exits fuel right up and out the vent tube which dumps it down the middle of ...
Car starts and after warmed up.. it dies!! HELP! - Honda-Tech
honda-tech.com/...del.../car-starts-after-warmed-up-dies-help-2797652/
Jun 28, 2010 - Car starts and after warmed up.. it dies! ... but if i let it sits for awhile till the engine is cool down it starts right up but after its warmed up.. it dies.
Troubleshooting an Engine that Stalls at Idle When Warm ...
www.gearheaddiva.com/.../troubleshooting-an-engine-that-stalls-at-idle-...
Dec 21, 2015 | Cars & Trucks
2000 suzuki vitara runs 15 min stalls wont start till cools down
Did they figure out if you are loosing fuel or spark when it fails to start up ? You would need to know which to proceed.
Feb 13, 2014 | Suzuki Grand Vitara Cars & Trucks
1996 mercedes c280 dies when put in drive
Engine stalls or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 15, 2012 | 1996 Mercedes-Benz C-Class
Tb144 troy bilt tiller, starts and idles fine, after it warms up, you can give it gas and it runs fine. when you let off the gas and return to a idle, then try to give it gas agian, it will die. then it...
Sounds like you have a dirty gas problem.
Empty the tank and remove it, clean it out and before refilling filter the gas to remove contaminants.
If this fails the problem is the carburator.
Remove it and disassemble and allow the body to soak in gasoline for about 15 minutes. the blow out all the port with compressed air and reassemble.
It doesn't take much to clog up those litte carbs.
Jan 31, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
1989 plymouth voyager stalls after warm up
you need to check what the fuel pressure is at the reed valve on the fuel rail when it dies,you need at least 50psi
Dec 03, 2009 | 1989 Plymouth Grand Voyager
Stalls when warm 95 camry
sound like your have the bad distributor, when you have trouble starting remove the distributor and have the auto part check it.
Nov 23, 2009 | 1995 Toyota Camry
Honda fg100 stalls when warm
Try giving it a quick tune-up. First dump the old gas (todays fuel can be considered old if its been setting for more than 30-days), pour it back in to a fuel can and put it in your car (it will be fine). Now add fresh "premium" grade (92 octane). Change the spark-plug. I just bought one at a discount auto parts store for $2.26. Finally, check the air cleaner. If it's a foam type clean it with water and liquid dish soap. If it's a paper filter you'll have buy a new one from a lawn equipment dealer (call first not everybody carries parts for Honda's). This should cure most engine problems, if it doesn't you may need to take it to a professional.
Apr 10, 2009 | Honda Garden
1981 buick skylark auto 4 cyl. dies when I give it gas
The float is probably mis-adjusted in the carburetor.
Either that or the choke is out of adjustment.
It would probably bne best to rebuild it if you can, or have it rebuilt.
Jan 19, 2009 | 1983 Buick Skylark
Briggs and Stratton dies after 15 mins
sounds like the head bolts maybe lose just check that first
Dec 26, 2008 | Garden
Craftsman 25cc Gas Line Trimmer Logo
325 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
