Question about Car Audio & Video
How do i remove the front dash board on a combo van just above the radio there is a little screen that lights up telling you the time,date and radio station.it does not light up so i want to remove it to see why.kind regards.joe.
Dashboard lights go off also rev counter and speedo stop working and flash off and on
Posted on Aug 15, 2011
  • 20 Answers
A lot of renault dashboards are secured by 2 screws behind the dash speaker covers - I have accessed my megane that way to change the same bulb
Posted on May 26, 2010
Headlights on 2001 Buick century won't go off & led on clock stays on
well there are a few things this could be. first on most dash boards up toward the window is a little square. this is usually the sun sensor. if covered or dusty the sun won`t hit is and your lights remain on. if it is damaged it will need to be replaced. there are also ways of using your lights manually. They does this with a combo or things at the same time. like putting your key in the one position and turning your lights on manually while holding a door lock or some other combo. Try pulling your battery for about 20 minutes and put it back on PS MAKE SURE YOUR RADIO DOESN`T HAVE A SECURITY SYSTEM AND IF SO MAKE SURE YOU KNOW THE NUMBER OTHERWISE YOUR RADIO LOCKS.
Feb 02, 2014 | 2001 Buick Century
How do i remove the dash on my 06 f-250 to replace the radio.
if the radio has 4 holes one in each corner then you can get 2 tools to push into the 4 holes and it then is loose to pull it right out
Jan 05, 2011 | 2006 Ford F-250 Super Duty
How do I remove the fan switch to replace it on the dash under the radio?
Have your radio code before you pull it out with the right radio tool. This pull would involve removing this parts.
  1. Glove compartment
  2. Driver side panel
  3. Center top dash board
  4. Defrost switch carrier
  5. Radio unit
  6. Center lower half of dash
So I'd suggest go to your local public library and look for your car manual. It would be either Chiltons or Clymers manual, it's not as precise a Bentley VW Official factory repair manual. Yes it really involves taking all those parts out just to get to the rotary switch.
Apr 20, 2010 | 2000 Volkswagen Beetle
Stereo removal help 1995 dodge caravan
i just did this! Take the plastic grid on your dash board (right in front of the information center above th steering wheel) off. You have to pry it with a lever (sqrew driver for instance.) You will see sqrews to unsqrew. then continue to pop off each panel on your dash board, starting with the one closest to your windshield. You will continue to uncover sqrews to be unsqrewed. When you pry and pop the panels off it is a little scary because it takes a bit of pressure. Next pop off the plastic panel around your stereo/dash board. I hope this helps! if you find a stereo color diagram for the stock radio, let me know because thats what i am trying to solve now!
Apr 08, 2010 | 1995 Dodge Caravan
Escort van need code for radio,can anyone help please? van is w req with m series radio
Normally the code is either in the manual, the glove box or behind the radio itself.
Check the radio last as it might require you to remove some panels, but try to slip under and behind the dash with a mirror/light first, could save you some time.
Feb 07, 2010 | 2000 Ford Escort
Chrysler 99' town&country idiot lights guages go on&off
This is a very common problem on 1998 dodge caravan, voyager, t and County. You have a cracked circuit board in your instrument cluster. It is a dealer item. You can remove your cluster and install the circuit board yourself to save money but after the install you will have to take the vehicle back to the dealer to have it calibrated before the tach and the speedometer will work.
May 27, 2009 | 1998 Chrysler Town & Country
91-chevy astro van tail/running dash lights won't work,
wiggle the headlight swith a little. I have this problem with my chevy truck
Mar 23, 2009 | 1990 Chevrolet Astro Extended
1990 Cougar No display dashboard or radio
I am not sure if you mean the dash lights or just the radio display
cause there was some models with small bulbs behind the dash and you had to replace the bulbs and some of them you had to replace the cluster and if you have to replace it and you go to a salvage yard look at the date just inside the drivers door and find one as close to that date as you can and it should work and as for the radio there is a bulb behind the radio
Jan 13, 2009 | 1990 Mercury Cougar
Car Audio & Video Logo
150 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
