Question about Xerox Office Equipment & Supplies
I am getting subsystem fault 10-310 what can i do to fix this?
    New Friend:
  • 51 Answers
Pls explain fully which model of xerox
Posted on Dec 12, 2010
2004 Ford Explorer 4 wheel drive wrench light on dash no power to ignition how do I fix
Find yourself a electrical distribution diagram an see where the B+ voltage to the ignition comes from . An you need to be a little more specific ! Ignition system or ignition switch .
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine size . Under system click on electrical distribution ,then under subsystem click on power distribution . Click the search button then the blue link's one at a time .
Do you know what electronic throttle control is ?
It should be noted that the ETC system includes a wrench light on the instrument cluster that illuminates when a fault is detected. Faults are also accompanied by DTCS and the "Check Engine Soon" light.
Your best bet mite be to take it to a qualified repair shop.
Sep 28, 2017 | Ford Cars & Trucks
What is the fix for Audi Fault code P1723
Trouble Code:
System:
Subsystem:
P1723 - (Manufacturer Specific)
Powertrain
Transmission Controls
DTC Description: Starter Interlock Circuit Open
Analysis:
Likely Cause:
Open Circuit
Possible clutch switch if manual transmission.
Sep 20, 2016 | Audi Cars & Trucks
What is the bmw code 2056 ?
if it start's with a P2056
Fault Code P2056 - Reductant Injector Circuit / Open (Bank 2) Unit 2
Trouble Code:
System:
Subsystem: P2056 - (ASE)
Powertrain
Fuel & Air metering, Auxiliary emission controls
Jul 25, 2014 | BMW X3 Series Cars & Trucks
I Have a subsystem fault 004-332 on a xerox 2045. Any ideas?
4.332 belt position failre as you can see the belt edge sensor sa detected that the drive belt is out of its position.
Jun 03, 2009 | Xerox DocuColor 12 Printer
16 bit MS DOS Subsystem error
I found a website of people who have the same problem;as you will see Microsoft does not have a fix for it. The recommended fix is to backup your data and reload Windows.
http://www.techspot.com/vb/all/windows/t-5039-NTVDM-CPU-illegal-instruction-.html
Pls rate this solution.
Apr 13, 2009 | Microsoft Windows XP Home Edition
Win 16 subsystem error. have to close applications and reboot.
Okay. The normal causes of insufficient resources in a Win16 app are the limitations on USER and GDI resources. This applies all the way from Windows 3.0 through WinME and the Win16 subsystem running under WinNT4.0 through Vista still are affected by these design constraints regardless of the actual amount of RAM installed in the computer.
But you can try this: Right-click on the executable for the application and select Properties. Click on the Compatibility tab. Check the boxes for 'Run in 256 colors' and 'Run in 640 x 480 screen resolution.' Try running the application again. If you still get the error, go back to the Compatibility tab and check the box 'Run this program in compatibility mode for:' and select the Windows 98/Windows ME in the drop-down list. Try the program again. If that doesn't work, go back to the Compatibility tab again and select 'Windows 95' in the drop-down list and try running the application again. Hopefully, it will run without errors in one of these configurations.
Mar 03, 2009 | Microsoft Windows XP Professional
Error 062-380
That is an imaging subsystem fault.
You can try turning the machine off, disconnceting and reconnecting the document feeder and scanner cables, then reconnect them to be sure they are properly seated.
Other than that, it would really need a service call.
Aug 14, 2008 | Xerox Office Equipment & Supplies
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
May 29, 2008 | HP LaserJet 1320n Printer
572 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
