Question about Brother Office Equipment & Supplies
How do i empty memory file for out going faxs MFC-790CW SER.# U62050J8F305687
  • dancer34 May 26, 2010
    SECOND TRY WAS OK WILL CONTACT YOU IF NEEDED.
    THANKS FOR YOUR HELP
  • 4,281 Answers
Press menu button->fax settings then clear memory or reset memory.So all faxes stored in memory are deleted.
Then fax Memory is clear then you can use that memory for store fax again.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 26, 2010
  • 1 more comment
    FOLLOWED YOUR SUGGESTION BUT MENU ON LCD SCREEN DOES NOT GIVE ME FAX SETTINGS OPTION TO CLEAR MEMORY HELP!
    HAVE YOU RECEIVED MY COMMENT ON YOUR SOLUTION SUGGESTION THAT DOES NOT ANSWER MY PROBLEM
    ROLAND WILLIAMS
  • 1. On the Touchscreen press the MENU.
    2. Press FAX.
    3. Press SETUP RECEIVE.
    4. Press the UP OR DOWN ARROW to choose MEMORY RECEIVE.
    5. Press FAX STORAGE.
    Then if you want to clear fax memory find clear or reset memory if you are not able to see it then turn the fax storage off then restart the printer then check.
    Then again turn on the fax storage if you want to store fax in memory.
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Canon printer 5440 "unable to print see troubleshooting routine maintenance manual" - message in led window
Open the scanner cover and remove any
foreign obstacles from inside the MFC. If the
error message continues, please follow the
steps below before disconnecting the MFC so
you will not lose any important messages.
Then, disconnect the MFC from the power
source for several minutes (which will erase all
faxes), and then reconnect it.
Check whether the MFC has faxes in the
memory
1. Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
OR
If faxes are present, you can transfer them to
another fax machine. Go to Step 3.
OR
You can forward the faxes to your PC. Please
see Transfer faxes to your PC.
Transfer faxes to another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3. Enter the fax number to which faxes will be
forwarded.
4. Press Black Start.
5. After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set,
9, 0, 2 in Step 1.
You can move the faxes from your MFC’s
memory to your PC.
1. Press Menu/Set, 2, 5, 1.
2. Using ▲ or ▼, select PC Fax Receive, and
then press Menu/Set.
The LCD will ask if you want to transfer a fax
to your PC.
3. To transfer all faxes to your PC, press 1.
OR
To keep all faxes in the MFC’s memory,
press 2.
4. After the faxes are transferred, disconnect
(For details see Using Brother PC-FAX
software
on page 5-1 in Software User’s
Guide on the CD-ROM.)
These steps is on user manual.
Jan 16, 2010 | Brother MFC-5440 Printer
Brother Fax MFC 790CW. Loaded the USB cable from fax machine to my computer and start with it would print from the computer though now it keeps saying offline all the time and even though when I right...
Hi there Jenny, are you using Vista with this printer? If yes, you can to the following:
1. Click the Vista Start button, and go to Control Panel
2. Click Hardware and Sound.
3. Under Printers, c
lick Change default printer.
4. Right click on the printer icon, select Run as administrator, and then click on Properties.
5.
If the User Account Control prompt is displayed, click Continue.
6.
Click on the Ports tab.
7.
Click Configure Port associated to your Brother MFC790c
8. Change the Protocol to Raw.
9. Then click OK.
Restart the printer and try again.
If this does not work, please let me know so that I can suggest other solutions. Goodluck!
Oct 25, 2009 | Brother Office Equipment & Supplies
Just bought the brother mfc 790cw wireless printer....theres no port to hook it up to my computer obviously and i have no users manual...how do i link it up with my computer?
You have to connect to the printer at least once with a USB A to B cable to set up the wireless system.
After that you can connect wirelessly.
Jul 05, 2009 | Office Equipment & Supplies
My brother mfc-790cw is sending but not recieving faxs.
it has been switched to "manual reception", or "tel mode" rather than "fax" or "Auto receive".
Feb 24, 2009 | Brother FAX-575 Plain Paper Thermal
Problem with my fax Machine MFC 420CN
You can cancel a fax job that is stored and waiting in the memory.
1 For MFC-210C,
press Menu/Set, 2, 5.
For MFC-420CN,
press Menu/Set, 2, 6.
Any jobs that are waiting will appear on the LCD.
2 If you have more than one job waiting, press ▲ or ▼ to select the
job you want to cancel.
Press Menu/Set.
—OR—
If you only have one job waiting, go to Step 3.
3 Press 1 to cancel.
To cancel another job go to Step 2.
—OR—
Press 2 to exit without canceling.
4 Press Stop/Exit.
That should do it for clearing faxes you dont need you can also print off all the faxes in the memory and I believe that clears it.
Enjoy,
Lee
Jun 12, 2008 | Brother MFC 420CN All-In-One InkJet...
How to empty fax memory.
The setting for resolution was too high. Set back to basic and fax went through--no more problems.
Feb 08, 2008 | Brother MFC-5440CN All-In-One InkJet...
179 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
