Question about Nokia 6233 Cellular Phone
Profile My phone's profile changes by itself and returns to the standard settings as if the settings were restored. Should I return this product?
  • 3 Answers
Yeah itr is faulty
Posted on Apr 08, 2008
6ya staff
SOURCE:
How to hard reset or format samsung SGH-A777 since my screen has gone white and i cant see anything :(
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the right soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (8)
  4. Highlight, using the navigation keys, any of the following:
    • All: Sound Profile, Display, Phone, Alarm and Bluetooth settings will be returned to default values
    • Sound Profile Settings: Only sound profile settings will be returned to default values
    • Display Settings: Only display settings will be returned to default values
    • Phone Settings: Only phone settings will be returned to default values
    • Alarms: Only alarm settings will be returned to default values
    • Bluetooth: Only Bluetooth settings will be returned to default values
  5. Press the a737%20center%20key%5b2%5d.jpg key to check the box(es) of the desired Reset Settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is "0000"
  8. Press the left soft key for OK
  9. If prompted, Enter the password again to confirm, using the keypad
  10. Press the left soft key for OK
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Jun 03, 2011 | Cell Phones
I have an sgh-a877, impression, and I can't find a reset button. Is there one on this phone?
  1. From the standby screen, press Menu
  2. Press Settings
  3. Press Reset Settings
  4. Press on any of the following to check their boxes:
    • All: Sound Profiles, Display & Light, Phone and Alarm settings will be returned to default values
    • Sound Profiles: Only sound profile settings will be returned to default values
    • Display and Light: Only display settings will be returned to default values
    • Phone: Only phone settings will be returned to default values
  5. Press Reset
  6. Enter the password default password is "0000", then press OK
  7. If prompted, Enter the password again to confirm then press OK
  8. Press Yes to Reset the handset's settings to the factory defaults
May 25, 2011 | Samsung Cell Phones
A767 got wet and now goes into downloading on screen and then locks up?
Sir, it's due to some problem in the Firmware. It better to reset the device.
For reseting your device either contact a service center of Samsung or do the following:--
  7. Enter the password, using the keypad, default password is “0000”
Or refer to this site: http://www.retrevo.com/support/Samsung-SGH-A767-Cell-Phones-manual/id/23135ag619/t/2/
Regards
Vineeth K.
Jul 20, 2010 | Samsung Propel A767 Cell Phone
Where is the reset button
If your phone is the samsung eternity and you want to reset your phone there is no button You must go to settings->Press on Reset Settings->
  • Press on any of the following to check their boxes:
  • Press on Reset
  • Enter the password, using the keypad, default password is “0000”, then press on Confirm
  • If prompted, Enter the password again to confirm, using the keypad, then press on Confirm
  • Press on Yes to reset the handset's settings to the factory defaults
  • OR
    type *2767*2878#
    Jun 10, 2010 | Samsung Eternity Cell Phone
    Tmobile mms settings for lg kf900 prada 2
    i got this from here
    From the home screen go to Menu, Settings, Connectivity, Network, Network Profile, Data Connections, New Profile. Fill in the spaces as follows.
    Bearer: GPRS
    APN: wap.voicestream.com
    User ID: Leave Blank
    Password: Leave Blank
    Primary Server: 216.155.165.050
    Secondary Server: Blank or all zeroes
    Now from the home screen go to Menu, Browser, Settings, Network Profile, New Profile. Fill in the spaces as follows.
    Homepage: http://wap.myvoicestream.com
    Proxy: On
    IP Address: 216.155.165.050
    Port: 8080
    Access Point: Select the Tzones profile you've created in the last step.
    Now click Save. It should return you to the previous screen with the heading Network Profile. Select options using the proper softkey and select activate. There should now be a checkmark next to Tzones.
    To make sure your settings are correct so far, use the browser's homepage to test that the settings have taken effect. You should see T-Zones homepage as you would on any standard T-Mobile phone. If it does not work, double check your settings and shutdown and restart your phone and try your browser again.
    For some reason I could not get our phones to work without setting up the browser as well, which is why I've included this step. Now on to the final step.
    From the home page select, Menu, Messaging, Settings, Multimedia Message, Network Profile, Add. Enter the following information.
    Profile Name: Picture Messaging
    MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    Internet Mode: WAP
    Proxy IP: 216.155.165.050
    Proxy Port: 8080
    Connection: Select Tzones
    Click save and return to the Network Profile in the same menu. Select Picture Messaging to activate it. There should now be a checkmark next to Picture Messaging. Now send a test text. If it does not go through, shutdown and restart your phone and try again. Once operational, you will have a phone that can use all major functions on the T-Mobile network including picture messaging, web browsing, and should also allow downloading of ringtones.
    Dec 02, 2009 | Cell Phones
    Samsung SGH a727 forgot password to turn on phone
    1. While in standby mode, press the left soft key for Menu
    3. Select Reset Settings (10)
      • All: Phone, Display, Profile and Alarm settings will be returned to default values
      • Phone Settings: only phone settings will be returned to default values
      • Display Settings: only display settings will be returned to default values
      • Profiles: only profile settings will be returned to default values
      • Alarms: only alarm settings will be returned to default values
    5. Press the center navigation key to check the box(es) of reset settings
    7. Enter the password, using the keypad, default password is “00000000”
    8. Press the left soft key for Confirm
    9. Enter the password again to confirm, using the keypad
    10. Press the left soft key for Confirm
    Sep 25, 2009 | Samsung SYNC SGH-A707 Cellular Phone
    When I close the phone the (ring) volume returnes
    hi sunshine,
    just set the same profile as you have on the opened one as to the closed one, this will not allow your phone to automatically select profile like on handsfree or not.
    regards
    Jul 08, 2009 | LG Shine KE970 Cellular Phone
    Xbox360 hard drive gamer profile corrupted
    sorry bro.. but the only way for you to retrieve your gamer profile is to delete the profile and then log in online... your gamer profile will be retrieved, all achievements will be restored but save games and game data will be lost... you can try to contact microsoft for further troubleshooting...
    thanks for using fixya... I would appreciate a fixya rating.. thanks alot...
    May 27, 2009 | Microsoft Xbox 360 Console
    Samsung sgh-A727 and I cant remember the power on password
    Mar 11, 2009 | Samsung SGH-a727 Cellular Phone
    6233
    Make sure a profile has'nt been timed, if not try:
    Restore factory settings
    To reset some of the menu settings to their original values, select Menu > Settings > Restore factory sett..
    Enter the security code.
    Timed — to set the profile to be active until a certain time up to 24 hours, and set the end time. When the time
    set for the profile expires, the previous profile that was not timed becomes active.
    Select Menu > Settings > Profiles and the desired profile. Select from the following options:
    Activate — to activate the selected profile
    Personalise — to personalize the profile. Select the setting you want to change, and make the changes.
    Mar 27, 2008 | Nokia 6233 Cellular Phone
    Nokia 6233 Cellular Phone Logo
    Top Nokia Cell Phones Experts
    jonathan mariano
    jonathan mariano
    Ekse
    Damen Wong
    Damen Wong
