Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I have a honeywell digital thermostat for my central air and it has a set, hold, run buttons and I just cant seem to set it right to keep the air running. when you hit set it flashes the time and then hit set again and the temp flashes
  • Brian Niten May 26, 2010
    What is the model #?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 195 Answers
Just use hold or call 800 honeywell
Posted on May 29, 2010
I had a Honeywell Thermostat RTH8500 installed by a pro to run Heat / Cool electric heating WITH central air conditioning. Problem : When running on cool Fan on auto ,it work OK but sometimes when the...
Is this a new hvac system? A new furnace can work differently than your old one. Does it shut off after a minute or two or continue to run? If it continues to run then call that professional back and let him fix it. If it shuts down after a minute or two then it is a feature of the new thermostat to squeeze all of the cool it can from the a/c coil and ductwork.Some of them have settings that you can adjust for blower delay on and off, read the manual that came with the t-stat and see if it does.
Jun 16, 2011 | Honeywell Heating & Cooling
I cannot get our house cooled down. We have a RTH230B Honeywell thermostat. The central air has been running for 24 hours. I set it to 72F and our house is still 82 degreesF
Did you go outside and check the exterior housing? Look for oil on the pad; accumulation of leaves, etc that restrikes air flow; and is the exterior fan running? I doubt if it is your thermostat!
On the interior, you should see some water coming from the condenser exhaust hose also.
Jun 04, 2011 | Honeywell Heating & Cooling
Not sure what type of thermostat to hook up to run it
Hello, most programmable thermostats will work with your unit. Honeywell and white rodgers makes good quality thermostats. Here is a link to some thermostats....http://yourhome.honeywell.com/home/Products/Thermostats/
Apr 02, 2011 | Ruud Central System Air Conditioner
TH8110U1003 Touch screen thermostats. My problem is I don't have a manual to show me how to operate it. But the big problem I'm dealing with now is when I set a temp. say I set it for 75 and the house...
If your program that you have programed into the stat is set to 73 it will go back to that setting if the stat is in the program mode....... Push the HOLD button on the stat and keep pushing it till it say permanent HOLD right above the buttons on the bottom and then you can set your temp to what you want. Here is a download link for the manual from Honeywell..
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf
Mar 22, 2011 | Honeywell Heating & Cooling
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
May 16, 2009 | Honeywell Programmable Thermostat Heater
I'm trying to turn on the central air conditioning in my new apt, and it's not working. I'm flipping the switch on the bottom right to Cool. It's blinking "Cool On" but also says...
Remove the front cover off the thermostat and jumper the power wire= r- to g==fan & r-to y==cool if it works, then its the thermostat!
Sep 01, 2008 | Honeywell Heating & Cooling
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
946 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
