Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
USB female cable pins are broken off,how do you fix this problem? Do you have to remove the hard drive from plastic case ?
    Top Expert:
  • Seagate Master
  • 76,649 Answers
Yes you will need to take the plastic case apart to fix this, your best bet to get a repair connector which is a mini usb is to contact Radio Shack, they can get the part, below u will find a link to replacing a usb female socket like your hard-drive uses, this has step by step instructions, this happens to be a cell phone but the procedure is the same on both circuit boards, excellent close ups of the job, if u don't have the tools to do this or the skill have it fixed by a pro, you can very easily ruin the circuit board bu using to much heat and not having the skill required to get this repair completed.
usb
-port-on-your-cellphone/">http://hackaday.com/2007/11/08/how-to-replace-a-mini-usb-port-on-your-cellphone/
Posted on May 26, 2010
How do i connect a hard drive in the usb port
You need a hard drive docking station. It has a USB cable linked to a hard drive plug-in connection. The plug-in section should have an option with the same pin arrangement as the hard-drive. The hard drives generally have male pins so the docking station should have female pins.The docking stations generally have more that one pin arrangements for different types of hard drives ie. SATA etc.
Check with your local electronics shop, if you have one, else explore Ebay and/or Google.
Feb 13, 2015 | Hard Computers & Internet
Power socket broken on usb3 1tb verbatim
If you cannot get the connector fixed then you need to remove the hard drive from the adapter case and insert the hard drive into a new adapter case.
Jun 10, 2012 | Computers & Internet
I have seagate 500gb sata freeagent. usb port broken. need to buy the pcb connector because I dont think i could solder back the broken usb port to the board. anybody know where to order?
I believe you are looking for this: USB Mini-B (5-pin) you are looking for the "socket"
Here is a list of products to choose from:
https://www.alliedelec.com/search/searchresults.aspx?N=0&Ntt=USB+Mini+B&Ntk=Primary&i=0&sw=n
Please note; This will be extremely hard. most of those products have no pictures and you are not sure exactly what you are getting, luckily they are pretty cheap so i would recommend getting a couple that sound right.
Good luck, be careful.
Hope this Helps.
Mar 19, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Usb input from hard drive to computer is broken
Will replacing the data-cable replace the broken-off piece?
If not, then for about $30, you can buy a new "empty" external case, and then "transplant" your current disk-space into the new case.
Take your current external drive to the computer-store, so that the new case that you buy will be the correct case for your existing disk-drive.
Of course, because you have a "small" (100GB) disk-drive, any warranty for the disk-drive probably has expired, and it would be good "preventative-maintenance" to buy a new external disk-drive, before your current disk-drive unexpectedly "quits" on you.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
USB cable has broken of the plastic.
If the cable is not permanently attached to your drive, you can easily replace the cable for very little money. I am not sure about in Norway, but right here in the U.S., we can run down to Big Lots to buy a new cable for like $4.00. But be sure you get the right cable. The are four different kind of USB connectors commonly used for PC accessories.
Sep 03, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have my female usb part for my external hard
You can get these parts from any good electrionic parts suplier eg Maplin, Mouser, RS components, etc but need to be competent at soldering.
You could just get another enclosure
Or you could remove the drive and install it inside a pc that has a suitable interface
Plenty of options
Aug 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Broken USB Connector (Garmin nuvi 200)
USB connectors are too fragile for the constant in-out service they get. But I have solved the problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Nov 20, 2008 | Garmin nuvi 200W GPS Receiver
FreeAgent 500gig External - How to open case?
I believe Seagate has a 5yr warranty with this drive. Why not have Seagate honor the warranty and have them repair or replace the drive?
Jan 16, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
79 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
