Question about Broan-NuTone CV750 Central Vacuum
The top motor on my Nutone CV-750 quit working
I ordered a replacement motor but when I installed it I neglected to attach the ground from the electrical board. When I turned it on to test the motors sparked. I imediately turned the vac off and connected the ground. Now when you turn on the switch nothing happens, it is like a fuse has blown. How can you test the fuse on the electrical board and where can you buy a new one if it is bad? Where can you buy the electrical board if it is bad.
reddevil6
  • 1673 Answers
SOURCE: Nutone CV 450
If the top comes off, it will be by the motor and exhaust. Just replace it with the new one, make sure you don't mix up any wires. Also unplug it from the AC first.
Posted on Jun 22, 2008
  • 95 Answers
SOURCE: I have a nutone CV-750,
It sounds like you could have one of two problems. I would guess either a short in your house, or a bad relay. If you plug you hose in sideways it will bypass the low voltage wire in the hose. If the unit doesn't shut on and off then you have a short and need a new hose. If the unit continues to cut on and off then you probably need a new relay. The relay is really easy to change out yourself and there are places to buy online.
Posted on Feb 13, 2009
  • 95 Answers
SOURCE: NuTone CV353 Central Vac does not start when hose is plugged into
Try to plug the hose in sideways. So the top of the hose is rotated 90 degrees. If the unit turns on then there is something wrong with the hose. It might be a short or it could be a bad switch on the handle. If the unit still wont turn on I would think that maybe the low voltage wire got disconnected from the unit or there is a break in the low voltage wire somewhere along the way. Let me know if you plugging the hose in sideways works.
Posted on Feb 22, 2009
  • 4 Answers
SOURCE: NuTone Central vac won't turn off
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. If the tank continues to run and still will not turn off, then most likely the relay inside is defective (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected the tank is able to then be turned off with the switch, then there is a short in the low-voltage wires or a hose is plugged into an inlet somewhere. ~ TTURAMBAR
Posted on Mar 27, 2009
Sparchitech
  • 5 Answers
SOURCE: Nutone CV-750 stops during use
This was one of Broan/Nu-Tone's beginning attempts at lower-decibel machines. Like so many of their competitors, they choked the motors in dense foam in the head unit and made it too difficult for them to cool. Make sure that you're not blocking or suffocating the ventilation, but don't be surprised... a plethora of makes and models like this one have had to be pulled and discontinued because of the overuse of muffling foam snuffing out good machines before their time.
Chalk it up to a design flaw and start yanking that foam out. The specs on this puppy make it far too good a machine to pass on just becuase of the manufacturer used you as a beta test before they should have relaeased it from proto. If the increase noise irritates you, read up on sound waves, frequencies and subsonics and get creative in how you isolate the parts that bother you. Chances are, though, you'll be just fine.
Lastly, if you can tell me the age of the machine and get me the numbers off the motors I'd love to know more about this situation you're in. You're running dual 2-stage bypass 12.5 amp motors. That puts you roughly in range of a Lamb 472, one of our industry's most hardy motors. If THOSE are what you're running and they're over-heating, you've got a firehazard in your vac that *somebody* never should have put certification on for marketing.
Posted on Jul 12, 2009
Central vac not sucking
Check for a plugged tube in the wall by listening to the motor when it's running. If it sounds like it's running too fast then there's an obstruction. If it sounds ok, then there's a disconnected tube somewhere in the system.
Sep 11, 2014 | Broan-NuTone CV353 Central Vacuum
The motor on our Nytone CV-350 is shot. Should I buy a new motor or replace the unit?
It depends on the age and condition of the rest of the vacuum and accessories. Check out the hose and power nozzle especially. If these look well worn, replace the unit. If it's a no more than years old, I'd simply replace the motor. Again, it depends on the condition, or expected "life" of the other components.
Jan 24, 2011 | Broan-NuTone CV-350 Central (Kit) Vacuum
A Nutone CV-450 System with inlet nozzle switch issues
You are suffering a connection problem of the hose end fitting to the wall outlet. Either the hose is not aligned with the two pins in the wall outlet, or the pins in the outlet are dirty and not making good connection to the hose end fittting.
Jan 01, 2010 | Broan-NuTone CV450 Central Bagged Central...
Have a nutone CV-450. Suction is gone at the
The first thing to do is to disconnect the pipe coming into the unit. If there is suction there than you probably have a break in the line. If there is no suction when you disconnect the pipe coming into the unit than it is most likely the motor gasket. This gasket can sometimes get sucked into the motor causing problems. Remove the lid to the central vacuum, than disconnect the motor, you should be able to tell if maybe the gasket has been off center or if it has been sucked up in the motor.
Dec 13, 2009 | Broan-NuTone CV450 Central Bagged Central...
CV 570 Relay not working, need a replacement. OMRON G7L-1A-TUBJ-C
There' s not much you can do if the relay goes. You just have to replace it. Are you positive that it is the relay?
Nov 30, 2009 | Broan-NuTone CV570 Central Bagless Central...
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
Nutone CV-750
You need to determine if this is a problem with the hose or the unit. I would recommend plugging my hose in the wall sideways. This should make your central vacuum run continuously. If the unit doesn't cut on and off it is the hose. If it still cuts on and off it is probably the relay.
Jan 06, 2009 | Broan-NuTone CV353 Central Vacuum
I have a nutone CV-750, and when I am using it, it will shut off and on.. What can I do?
Nutone cv353 central vac blew up
My guess would be that the motor is done. Impossible to diagnose for sure without seeing it of course. If you were happy with the unit before the trouble, a replacement motor will probably run $250-$300. If you are interested in a new unit, shop around. There are definitely better designed and more powerful units out there, although some of them can cost quite a bit more than $300. Good Luck!!
Dec 14, 2008 | Broan-NuTone CV353 Central Vacuum
Nutone CV 450
Jun 22, 2008 | Broan-NuTone CV450 Central Bagged Central...
Broan-NuTone CV750 Central Vacuum Logo
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
