Question about HP OfficeJet 6210 All-In-One InkJet Printer
Cant't send out any faxes.
I can't seem to send out any faxes, It keeps on saying no answer even when I know the other person's fax machine is on, And waiting for my fax, This happens with any number I dial it always comes back as no answer?
  • 3 Answers
Are you using the little cord that came with the printer to hook up your fax. It is a special cord. You cannot just plug a phone line into the fax.
You have to use the little cord, or equivlent. Go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00014834&lc=en&cc=us&product=421991&dlc=en
Posted on Apr 16, 2008
Just checking..we have a brother fax Intellfax 4750 and we can send out faxes however no faxes are coming in. It says receiving on the display but ringing in busy from the person sending the fax...any...
Call your fax machine from a telephone...have someone watch your fax and see if it answers...also listen on the telephone and see if you get the "tones" that a fax gives.....if your fax just keeps ringing then it just may have been set to the "tel" (telephone) mode...set it back to the Fax mode.
Oct 25, 2010 | Office Equipment & Supplies
Faxes not coming in - what do I do?
i beleive you can send faxes right but cant receive them..are u using an answering machine..make sure that u set the ring of the fax two tones higher than the answering machine..and also make sure that that the auto answer is also on in your printer..also ensure that your telephone service does not provide voicemail service..otherwise all faxes will go to voice mail..it should have distictive ring pattern..thanks
Jan 28, 2010 | HP Officejet 4315 All-in-One Printer
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Will not send fax
Hi:
If you can not send a fax the first thing to do is see if your fax machine has a monitor button or a handset. If it does press the monitor button and see if you can hear a dial tone. If you can't hear a dial tone then your phone line is the problem.
Mar 13, 2009 | Office Equipment & Supplies
I can only receive faxes not send when i try to send it just keeps ringing will not transmit
If you dial a number and just hear ringing that means the other end is not answering. Even if a person or answering machine picked up the ringing would stop. The problem is at the other end.
Mar 10, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
LEXMARK X5495 New printer, can't send receive faxes
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines
Jan 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Answering machine problems with Lexmark X4270
Thats an easy one, if the all in one is attatchd to pc and not stand alone, go into your pc settings, go to printers and faxes under control panel and take the fax off default setting. It will no longer be able to dial the fax and should revert to answereing. also check if your fax mode is set correctly for what you want. It may be on fax mode only so it automatically dials fax. Good luck.
Nov 17, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
Aug 25, 2008 | HP 1010 Plain Paper Inkjet Fax
Brother Multi function centre with fax, MFC 885CW we have the setting on F/T, it answers a fax after 2 rings, if a call coming in it keeps ringing, but on callers end it keeps beeping fax noises, callers...
I had the same problem using my Brother MFC 8460N fax on the same line as my regular telephone, which has an answering machine.
There was nothing wrong with my equipment. It was a set-up issue. I solved it as follows, and maybe this will be helpful to you:
Here's what I did, step by step:
1. Put your MFC and your telephone near each other, and within reach of a phone wall jack.
2. Go to the fax machine. Take the telephone line with the clip on the end of it that comes out of the fax machine. Put that into the telephone wall jack.
3. Go to the answering machine. Take its telephone line with the clip on the end of it and put that into the BACK OF THE FAX MACHINE. The port on the back of my fax machine says something like EXT TAD which means external telephone answering device.
4. Go back to the fax machine. You'll now need to play around with the menu options for the fax. My Brother MFC shows this stuff in a little screen on the front. Try and find the Fax Setup options. Next, try and find the Fax Receive options. If you do, select something like External TAD fax receive mode. Do not give up, you're almost done.
5. Next, set ring numbers on both devices, the fax machine and the answering machine. I set both devices' ring numbers to 4. I don't know if these are the optimal settings, or what happens if you set them at different ring numbers. I only know that a "4 and 4" setting works for me, and am not inclined to mess with it.
6. Final detail: the setup should be transparent to a voice caller. Someone who is sending a fax, though, might be a little confused IF, like me, they lean over to listen to their fax machine dial and screech, just to be sure it's working. Such a person may faintly hear my outgoing answering machine message before they heard my fax machine's screech kick in. They might think that they had a wrong number, cancel the fax, try again, call me with questions, etc., etc. So I changed my outgoing message to something like: 'You have reached xxx xxx xxxx. To leave a voice msg, please wait for the tone. To send a fax, please continue the transmission and it will be printed. Thank you!'
That's it. Hope this was helpful.
Best,
Wilbere
Check out my listings on http://stores.ebay.com/WILBERE
Aug 07, 2008 | Brother Office Equipment & Supplies
Fax machine
what do you mean? you cant send? or you cant receive fax?
first know if you are using a digital or analog line. if youre using digital line you need to have a micro filter and it must be connected to the fax line. if you have an answering machine it must be connected at the back of the printer(EXT-2) to make it work. then on your printer press menu and then choose fax settings
answering mode must be YES(if you have an answering machine)
rings to answer is 1 ring less than your answering machine
disable call waiting must be set to NO.
let me know what happen
May 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
258 people viewed this question
Ben Johnson
