Question about Garden
My Kubota B6100D tractor has a front PTO whose spline is 18mm and 22 tooth. I can find no such sized spline coupler anywhere. Kubota no longer makes them. Any help out there? It may be Japanese, but it's not junk.
4 Suggested Answers
SOURCE: Hi, looking for a manual for a Kubota ZB1-16
hi looking for a free website for a manual for kubota z48 engine workshop manual help me please
Posted on Sep 10, 2009
  • 62 Answers
SOURCE: Headlamps quit on L4200 kubota tractor, Wireing
CHECK THE FUSES
Posted on Sep 25, 2009
  • 394 Answers
SOURCE: DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Posted on Apr 30, 2010
Testimonial: "Hit on the head with such a simple solution"
Would like to add a creeper gear to my Kubota M110 tractor. I need to achieve .8 mph at 540 pto rpm's. Can it be done.
the specifications for the tractor show a transmission int-shift 24f/24r/(32f/32r) option with creep
creep speed is ( casset e type is listed at optional(.19-.74km/h)
.74 km/h = .459 miles /hr
the specs show that the pto speed is 500 rpms /1000rpms ( interchangable rpm)
reference www.kubota .com.au or m110gx-kubota tractor coorporation
you will have to talk with the service dealer technicians as from the specifications , what you want is available as an option
if not and you are using some sort of seeding machine , it may be an option to change the gearing in that machine to achieve the same results
May 16, 2017 | Kubota Garden
I have a kubota 9000 tractor, when I engage the pto the tractor dies
You may have a faulty safety switch in the seat.
Oct 08, 2016 | Kubota Garden
PTO lever engages in the wrong position in a Kubota ZD323.
Check and make sure that any links are not bent and make sure that the switch that engages the PTO is not out of adjustment.
Jul 14, 2016 | Kubota Garden
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
Kubota F3680 stalls when PTO is engaged
there is not enof power so olter the tick over
Jun 28, 2015 | Kubota Garden
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
How many horsepower does a kubota tractor B8200 has / what year was it made
It was made between 1983 and 1990
Kubota B8200 Power:
Engine (gross): 19 hp [14.2 kW]
PTO (claimed): 16 hp [11.9 kW] (gear)
14.5 hp [10.8 kW] (hydro)
You can find more breathtaking information about this tractor at
http://www.tractordata.com/farm-tractors/001/2/7/1274-kubota-b8200.html
Apr 29, 2015 | Kubota Garden
ONLINE PARTS DIAGRAM FOR KUBOTA ZD331
Go to Kubota Kpad Site. You must be running Windows Internet Explorer or the correct add-ons to access to site. Also you need to know which size deck you have.
Here the front part link.
Kubota Tractor Corporation Parts
Apr 05, 2015 | Kubota Garden
Pto onmy kubota zero trun zg 23 wont work
Check to make sure you are getting power on both sides of the switch. Check the connectors going to electromagnetic engagement PTO unit. This is mounted right on the base of engine. Check ground wire coming from unit to make sure you have agod grounfd connection.
Feb 27, 2014 | Kubota Garden
Garden Logo
162 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
