Question about Alpine iDA-X200 Car CD/ MP3 Player
Hopw to change color on ida-x200 - Alpine iDA-X200 Car CD/ MP3 Player
5 Suggested Answers
  • 152 Answers
SOURCE: 2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Posted on Mar 22, 2009
rcampsr
  • 90 Answers
SOURCE: Need to know what wires are for what to change out
The best thing you can do for your situation is to get a vehicle wiring diagram for your particular vehicle. This can be done at the dealer or by buying a vehicle manual at the autoparts store that has the wiring diagrams in it. You can then see the wiring color coding. They also make a factory plug pigtail that you can plug into your existing radio harness and then wire it correctly to the new radio. The new radio should have the wiring layout included with its documentation, and some radios also have small marking tabs on the wire ends to tell you what they are for. Good Luck, RAC
Posted on Apr 18, 2009
smarthome2
  • 1114 Answers
SOURCE: my alpine ida x200 keeps skipping during songs
All you can really do is use a CD Player cleaner *one that uses fluid* run it thru a couple times and try a disc again. Clean your CD's with liquid car polish an a microfibre towel, it works wonders for new and old CD's. If it still skips, It needs to be pulled for repair. They just replace the transport, usually runs between 100-150 depending on the service center. Hope this helps.
Posted on Aug 11, 2009
pasannothome
  • 3 Answers
SOURCE: my ida x200 says intrrupt
1) Press and hold Func/Setup for more than 2 seconds2) Using the Volume knob go to the sub function called General3) Then go to INT MUTE4) Then set it to OFF
This will sort your problem out hope this helps
Posted on Oct 15, 2011
My ida x200 says intrrupt on screen, no controls
Jun 30, 2011 | Alpine iDA-X200 Car CD/ MP3 Player
My alpine ida x200 keeps skipping during songs
Aug 11, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
I need a manual
if i were you id go to alpine.com or go to google and try to find the phone number for alpine
May 25, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Sat radio not working
It's a Bad SIRIUS Tuner. there have been lots. If it's in warranty, have it replaced. if not, you can still find that unit for around $50 from Crutchfield etc. Hope this helps.
May 22, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
I just had an alpine iDa-x200 interface unit installed in my car. It connected to my IPod fine the first day. Now it says "no usb device" I've checked the connections and they're fine. Why doesn't it...
Ive had the same problem with pioneer. I reset the unit and it worked once again but wasnt perfect. Id call Alpine cust. service tech to see about any "known" issues.
May 19, 2009 | Car Audio & Video
How do you install radio to account for usb port
ipod shows its connected but no audio comes out
Apr 18, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Need to know what wires are for what to change out stock radio in 1993 geo prism, to a new radio iDA-x200
Apr 18, 2009 | Car Audio & Video
2003 silverado z71
If not....
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Installing the Alpine IDA-X200
So it is powering up? On your actual deck will be a picture of the schematics of the wiring. With the system powered up, assuming you taped up the power wires, strip the front left wires coming from the deck and use them as your tester. You now know forsure they are for the front left so as you go through your cars audio wires you will find which wires are for which speakers around your car. Label them as you test them. Hope that helps.
Jan 14, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Alpine x200 Subwoofer Preout pushing out a weak signal
Hi, just turn up the gain, though the max voltage may be higher, it does not mean the audible output is higher, alpine decks subwoofer control is an attenuator, so at max it will be the same level as front n rear, on min it is -15db... you will probably find the kenwood is +/- 7db so it has a gain boost...
just crank up the amp gains, problem sorted...
Dec 11, 2008 | Alpine iDA-X200 Car CD/ MP3 Player
Alpine iDA-X200 Car CD/ MP3 Player Logo
190 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
