External LG DVD drive is not recognized after upgrading from Vista to Windows 7
    President:
  • 1,138 Answers
Try to install the usb driver compatible with your windows 7..
If your external drive also come with its cd installer, try installing the driver for this hardware compatible for windows7.
hope this help..thanks..
Posted on May 26, 2010
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Upgrade windows
The specs say this machine has a Core Duo processor, so it should support Windows 8. However, the RAM limit for this model is 2GB, so it'll be sluggish on 8. Windows 7 would be better.
It has a DVD drive, so it SHOULD be just a matter of buying the Windows 8 DVD and booting off the DVD into Windows 8 Setup. A 'clean install' is recommended; you may not be able to upgrade from your current version of Windows (this machine came with XP and Vista).
Oct 10, 2013 | LG Xnote RD400
Dvd not working in bios or Windows 7
It's a common problem when upgrading a OS? Is the DVD rom the only component that's missing a driver? Any Unknown Devices? Have you opened the Device Manager and looked for the DVD? In Device Manager, Scan For Hardware Changes. Not Listed? Have you done ALL your windows Updates? All the HP updates? Try the driver here: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-58707-1&cc=us&dlc=en&lc=en&os=2093&product=3548266&sw_lang= Download the software and SAVE to a folder. Modify the compatibility of the software from Win 7, using this procedure: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/ BEFORE YOU START, CREATE A RESTORE POINT. With this procedure: http://windows.microsoft.com/en-US/windows7/Create-a-restore-point.
Jan 13, 2013 | HP Pavilion Computers & Internet
Updating windows Vista to Windows 7. Getting error code 80070005
Its better to do a clean re-install than upgrade. You will have more problems after upgrade. Just back up your data (external drive recommended) before you re-install.
Jun 18, 2011 | Microsoft Windows Vista Home Premium DVD...
I need solution for this problem immediately I installed windows 7 in my PC. after that in My PC DVD RW is not working.
Was the Windows 7 installed from a clean slate or you upgraded from Vista to Windows 7? If you have upgraded from Vista to Windows 7, then this is definitely a driver problem. You can try to update the driver by going to Device Manager, check if the DVD drive is listed. Pull down the drop down list, and right click on the devices listed under DVD/CD-ROM Drives and choose Update Driver Software.
If the DVD drive came with a software bundle (e.g. Nero Burning Application) Try reinstalling these application under Windows 7 Environment.
Mar 26, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Hi i have a toshiba qosmio x305-q712 laptop it came with windows vista then they sent me 7 upgrade how do i recover the laptop to factory seting i know there is recovery disc creator but i just wasted 5...
* It is not necessary to back up ur data. U can simply run the Windows 7 upgrade, it will not delete ur files and folders. It will only replace the windows and system files.
** If u want to back up ur data then simply copy ur all data to another partition except C drive (System Drive) and then install a fresh copy of windows 7 and by format only c partition.
*** If there is only a single partition, then simply copy all your necessary data to CD/DVD aur pen drive aur any external hard drive and install a fresh copy.
**** U can also use Partition Magic to make two partition by cutting some space from C drive in case of only one partition.
Jan 31, 2011 | Computers & Internet
I'm running my laptop on win XP and I've got a problem with my CD/DVD-ROM somehow my system doesn't recognize it there for I can't use it, but I really want to upgrade my OS to Vista as originally my...
Here is what I suggest. I would go ahead and upgrade your OS. Windows Vista actually has worse performance than Windows 7/8/10. I recommend installing via USB flash drive. https://www.microsoft.com/en-us/download/windows-usb-dvd-download-tool
If you really can't get your hands on an upgraded OS. Here is a link that might help you to resolve your problem: No CD Rom drive in Device Manager No error reported by XP Windows XP
Otherwise I think it might be a driver issue. If you could supply the product serial I could point you to some proper drivers.
Jun 29, 2017 | LG GSA 4163B DVD±RW Dual Layer Burner
WD Elements external hard drive not recognized/can't be found
ur vista version has a problem with usb portable devices so either u have to upgrade ur vista to the latest on or install windows 7 or down grade ur laptop and install windows xp
Jul 27, 2009 | Computers & Internet
Need Vista driver for external DVD writer of LG model GSA-5169D
There aren't any such drivers.  The drive control protocols are standardized.  Just do Windows Update a few times and make sure the thing's connected when you restart storage subsystems (pretty much a reboot; though installing Nero will of course get things going if you don't love Vista built-in tools.)
Feb 22, 2009 | LG (GSA-5169D) DVD RW Dual Layer Burner
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
