Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Air Flow is blocked and TV will automatically shutdown. The air flow is not blocked
  • Mitsubishi Master
  • 3,866 Answers
If the airflow is not blocked then indeed this is a sensor or a fan issue your going to need to ether have a repair guy come out and investigate the issue or get yourself a service manual and try doing the job yourself.
We beleave its a sensor by what you described.
Please do be considerate the the answer was free and we are trying are best to diagnose without having it in a shop when you leave you postive feedback and ratings for all the experts invovled in your case today.
Posted on May 26, 2010
My computer is automatic shutdown
Have you cleaned the fan, vents, heatsink? If a laptop overheats, due to dust, poor ventilation, blocked vents, it will shut down to prevent damage to vital components. Clean, improve air flow through the bottom and out the vents. Never use on soft surfaces that can block air flow. Contrary to the name, Laptop, it's not good to use on your lap. Go figure? If the Laptop is Clean and air flow isn't a problem, open Power Settings in Control Panel,and change Advanced Power settings to Sleep/Hibernate to Never, set to High Performance, unplug and remove battery when not in use. If you use mostly on AC remove battery.
Sep 24, 2013 | Computers & Internet
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
After my vp800 plays for a hours it cuts off. WHY?
Remove the cover and check whether the air filters blocked with dust.
Whenair filters are blocked, air doesn't flow freely through the projector. This result in overheating, leading to automatic shutdown.
Sep 21, 2011 | Lightware VP 800 Plus Multimedia Projector
PJD 5111 Viewsonic projector shuts down after 10minutes?
Hi! I think it is the time to remove the cover and check for air filters blocked with dust.
Sep 20, 2011 | ViewSonic PJD5111 Projector
Tv blacks out and saids block air flow
Call Mitsubishi and they will tell you a authorized service center in your area to come out and fix this issue. They have a recall on the thermal sensors in these sets. They will pay for the repair.
Oct 17, 2009 | Televison & Video
Tv says air flow problems
ok what you have there is a faulty thernal sensor nitisubishi has issuued a bullitten to serice centers so check with local service center the repair might be covered under warennty
Jun 18, 2009 | Mitsubishi WD-Y65 65" HDTV
Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Jun 04, 2009 | Mitsubishi WD-65731 65" HDTV
Trane XE100 and I am getting an icing condition resulting in a shutdown. The fan apparently was operating but not moving any air through the room vents.When I took a panel off the fan assembly I got plenty...
Sounds like you are low on freon or you have some type of obstruction that is blocking the full flow of air across the coil.
Go for the simple thing first which is make sure you don't have something blocking the flow (like one time I found a plastic bag from the grocery store that had been sucked into the return grill and when the fan came on it would lay on the A-coil blocking the flow).
If that's not the problem then you are probably low on freon and should have the system charged.
May 18, 2009 | Heating & Cooling
Mitsubushi 1080 HDTV has an air flow block
There is a fan in the back. Make sure that the fan is spinning and that the grille is clean. It is possible that the sensor is bad too.
Keep us posted.
Dan
Jun 06, 2008 | Televison & Video
Wd-65731
AIr flow is blocked?.....is this the message you get on screen mitubishi have a problem with what is called the thermal sensor.. the processor says its getting to hot... mitsubishi suggest service center replace this thermal sensor.
Jun 02, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
255 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
