Question about Cub Cadet Garden
Trying to find wiring diagram for cub cadet 1811, model# 149-660-100. Someone cut off and discarded ignition switch. Need to know where wires get hooked up at. Red wire, White wire, Light Blue wire, Black wire, Yellow wire.
boscia
  • 163 Answers
SOURCE: hydrostat pump leak,cub cadet garden tractor
try tightening the connections. if that doesnt work you can disconnect and wrap the threads with teflon tape but this requires draining the hydro system
Posted on Nov 30, 2008
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
Dolfoff
  • 148 Answers
SOURCE: CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 13 Answers
SOURCE: I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Posted on Apr 16, 2010
Cub cadet zero turn 44"
You can get that from Cub Cadet's website
Dec 06, 2016 | Cars & Trucks
1500 model. where can I get a wiring diagram?
Hi Rodney,
Here is a link to one of the Cub Cadet 1500 Series with a wiring diagram. Yours may be similar to this. If you are NOT Sure, take the mower to the shop for Repair/Service.
Best of Luck,
JP
Cub Cadet 15HP Force 44 53AA5D2L100 Operator And Service Manual Wiring...
Jun 22, 2015 | Cub Cadet Garden
Cub Cadet 2150 ignition problems. Need a wiring diagram to source problem.
don't have a diagram but i would check the safety switches jump them while looking for the bad one with a paper clip
Apr 11, 2012 | Cub Cadet Garden
Garden Logo
594 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
