Plustek OpticPro 12000P Flatbed Scanner
Problem for Plustek OpticPro 12000P Flatbed Scanner
Problemas con xp
By cesarblases on Apr 07, 2008
Tengo un problema: cuando le doy a escanear, aún seleccionando todo el área de escaneado, no llega al final del cristal. Y he probado con Windows 98 SE y funciona perfectamente. En la ventana de predigitalización llega hasta el 26, y escaneando llega al 28, que no es un A4.
Creo que es un problema de Drivers, ya que Plustek no hace el driver de este scanner para xp. Alguien me puede ayudar?
Gracias
Popular Solutions for Plustek OpticPro 12000P
Questions and Unsolved Problems for Plustek OpticPro 12000P
Do you recommend Plustek OpticPro 12000P Flatbed Scanner?
Answer
Answer
I need a serail number from a plustek scanner to install a software that I use to edit photos and... (More)
Answer
I have uninstalled my scanner and when I came to re-install it I found the CD was for Windows 3.1... (More)
Answer
OpticPro 12000P scanner on XP worked fine for past number of years suddenly results in b/w printouts... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Plustek OpticPro 12000P...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 801
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
