Question about Mitsubishi WS-55859 55" Rear Projection Television
Mitsubishi WS-55859 power on problems - green light blinking
After a power outage the green light just blinks.  I tried resetting system AND PLUGGING  AND UNPLUGGING and all I get is a constantly blinking timer light.  This happened once before but it finally resolved and we had no problems until now.  Any suggestions??
    Genius:
  • 3,422 Answers
HI,
The only way to fix this problem is to call a technocoan and get it repaired.As you had a power outage the system has gone into protection mode. There are some of the fuses which has to be replaced but you may also have problem with convergence IC's.
Few troubleshooting steps you can try:
1)Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
2)The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
Goodluck,
Please don't forget to rate the solution as fixya..
Posted on Apr 07, 2008
    Genius:
  • 1,030 Answers
Have you tried holding menu button down for ten seconds... sometimes the front panel gets locked
SOURCE:
Tv modle wd-62725 after power outage timer light blinks constantly and will not power on even after trying system reset
what do i do when this problem occurs ive already tryed to do the reset button but that didnt help at all?
Jun 30, 2010 | Mitsubishi WD-62725 62" Rear Projection...
After a power outage my wd62525 won't restart.......the green timer light has been blinking for more than 24 hours HELP!! (I did try to reset, same blinking)
There is chance that the power outage might have damaged the power supply. It does happen, it's most common with storms. I recommend that you go to a shop and get that board checked
Dec 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
MY GREEN TIMER LIGHT WILL NOT STOP BLINKING
The manual indicates that this can be caused from recovery after a power outage, although it doesn't indicate thow long this lasts.
I recommend two courses of action:
Disconnect the television from power and let it sit overnight before plugging it back in.
If this doesn't work, reset your TV according to the instructions in your manual.
Oct 24, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Had power outage and after hitting reset button green light blink
Hard to say without looking and sniffing!
But if you suspect that it is and it is likely, you may be able to get it repaired on your insurance policy. It should be covered under FUSION
Dont mention the lightning but check your policy. Then get the repair guy to write fusion problem on the receipt and submit for claim.
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Restart problem
You may have to hard reset it by unplugging the cord itself and plugging it back in. When power comes back during power shortage, there may be a power surge rushing to the modem/router causing it to behave abnormally. Also, you may want to put power surge protection on it as it may damage you modem/router as i did mine.
Sep 17, 2008 | Acer Aspire 5100 Notebook
Mitsubishi WS-55859 55" Rear Projection Television Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
