Question about Toro 15" Electric Trimmer&Edger
Weedeater line keeps breaking - Toro 15" Electric Trimmer&Edger
  • 420 Answers
I sounds like the line is old and has become brittle.
Posted on May 27, 2010
Line on crafstman weedeater
wind it in the other direction.
Aug 10, 2017 | Weedeater Garden
Tip
Weedeater line breaks all the time?
this is one of the best tips i have come upon myself. one time i was fixing the broken string trimmer line again and the string was very dry. i tried spraying it with WD40 and what a miricle. now everytime i change the line i spray the line several times with WD40 as i am wrapping it. this has completely stopped all those nuissance episodes when the line melts to itself and then breaks off. try this and you to will be amazed at how wonderful it is to be able to run your weedeater until the line runs out and then you replace it without all those stops in between!
on Jun 20, 2010 | Garden
My feather light is leaking fuel throughthe exaust how do I fix that Weedeater
Check the little plastic fuel lines for breaks or loose connections. If they are good, search YouTube for video on how to clean/overhaul the carburetor. Also make sure your primer bulb is not cracked.
Online parts stores will have parts diagrams to show were the fuel lines go.
Aug 31, 2014 | Cars & Trucks
Only runs on choke
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
Jan 10, 2018 | Craftsman 25cc Gas Line Trimmer
Poulan pro weedeater will start fine run untill you pick it up then dies
poulan has a bad habit of the fuel breaking inside the tank if it breaks before the fuel filter that makes the fuel line shorter
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Garden
Weedeater trimmer not engaging
maybe on reassembly the drive shaft did not align properly.
Jul 18, 2009 | Garden
Ryobi BC30 Weedeater - Cannot Start
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 20, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman 25 cc weedeater keeps shuting off, was running fine
Probably fuel line into tank has hole in it, If over 5 years old these fuel lines become brittle and break easy. Go to local hardware or repair shop that has small engine parts and you should find the fuel lines. Be sure to take sample with you as there are many sizes. If you have trouble installing them get back to me. Be sure you know how the lines are routed before removing.
Apr 05, 2009 | Craftsman 25cc Gas Line Trimmer
Toro 15" Electric Trimmer&Edger Logo
390 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
