Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
The dishwasher is not draining so there is standing water at the end (about 2 - 3 inches. No leaking or backup. Any ideas?
  • 901 Answers
Check the main drain system for clogging. Pull the drain hose and inspect the connecting junction of the main drain down.
Posted on May 27, 2010
Standing water in dishwasher
Good Afternoon friend, thank you for your post!
I understand that you have some standing water inside of your Frigidaire dishwasher. It is a normal operation to have anywhere from 2 to 3 inches of water inside of the tub of your dishwasher. If it is anything more than that you could have an issue with the drain pump or drain line.
You may want to check the drain line for any restrictions or clogs that could cause improper siphoning from your dishwasher. You should also make sure that the filter located in the bottom of your tub is clean, that could cause water to stand within your dishwasher. I hope this information is helpful. -Matt
Mar 11, 2015 | Frigidaire Dishwashers
Im getting standing water at the end of the washing cycle.
Possible that there is a leak at the drain hose, failure of holding clips--, failure of drain valve/pump, failure of gaskets in the drain or door or it can be an over flow on the chamber due to failure of the drain.
Your observation to find the source of leak in the washer.
Jan 22, 2011 | Frigidaire Professional Series 24 in....
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Leaking dishwasher
It sound like while the assembly of the garbage disposal, you placed the end of the drain line pipe in a lower position than it was before. Good luck!
Aug 06, 2007 | Kenmore 15129 Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
172 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
