Question about Whirlpool Gold Black-on-Black 25.4 cu. ft. Side-By-Side Refrigerator w / Accu-Chill Temperature Control System GD5SHGXLB
Icemaker overflows water , repairman has replaced the icemaker twice, after this last time, it started making 1 tray of cubes per week, then after about 2 weeks, started overflowing water again.
    President:
  • 1,218 Answers
Good day,
If it is erratic as you describe and replacing the ice maker twice has not resolved the issue it would make sense to replace the water valve in the back rear of the machine, if it hasn't been done so yet. It's the flakiest part of the system and has the highest failure rate. It's been known to fill too little, to much, and sometimes not at all.
Posted on May 26, 2010
How to fix lower freezer, the water dispenses too much into ice cube tray so it overflows into ice bin...
There is an adjustment on your icemaker that controls the amount of water that enters the tray during the fill cycle. Find it and turn it counterclockwise to lessen the water in tray so it does not overflow.
Or, check to make sure that the fill solenoid is shutting down properly (could be sticking)- if not excessive water will enter the tray with same result.
Mar 03, 2017 | Refrigerators
Kenmore icemaker tray leaking water (model 795.51022.012)
Do the old 'KISS" thing first (keep it simple ......thing). Chances are that there are tiny calcium deposits in the ice tray which makes an ice cube stick in the tray. If one ice cube sticks, the water will overflow as it needs all the trays empty for the filling. The water will drip down into the freezer area causing chunky ice and stalagmites. The calcium deposits are very teeny in size but will hang up an ice cube from dropping. If more than one ice cube (basically all the ice cubes) didn't drop then the heater in that unit that initially gets the ice cubes to drop could be bad.
I've taken the ice cube assembly out and used vinegar with baking soda to dissolve the calcium and that worked. I left it in for a couple of days. "Do NOT" use anything like a knife or whatever to scrape the bottom of the tray as it will destroy the finish and keep the ice cubes sticking.
When I had the warranty service come out, the technician explained what happened to the tray (calcium). He replaced the tray but the next time it happened I used the vinegar and baking soda. I eventually bought a new tray for 1/2 the price on the internet when the problem happened later on in life.
Jun 13, 2014 | Kenmore Side by Side Refrigerator
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice cube tray overflowing-not shuting off automatically
Yes that is a plastic extension for the icemaker shut off. When replaced the new one should be secured with two small zip ties. You can use the ice on/off button to shut the icemaker off manually in the mean time. When ice is displayed in the panel it is on and when it is off so is the icemaker.
Jul 20, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
My french door with freezer at bottom ,LG icemaker making very little ice.
Perhaps there is not enough water coming into the tray on each cycle? Are the ice-cubes very thin? If so timer needs to be reset. LG use a 3-switch DIP on a control panel near the main power board. By changing these switches to various combinations of on/off you can change the timing - longer means more water each time (but too much water means overflow into the blocks already made).
There are service manuals that explain what each setting does - but because its near the high-voltage power board, I'd suggest you get a repairman unless you are a good DIY'er
May 12, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Water is leaking in side the freeze
It's the pump for the icemaker/water dispenser. When it goes bad, it just starts pumping water into your icemaker until it overflows into your freezer. You simply have to replace the pump. It's happened to mine twice.
You can very easily replace the pump yourself in about 3 to 5 minutes, and the pump only costs about 48 dollars.
Here's a link to the cheapest place to buy the pump: http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=RS22AQXKQ&searchTerm=&RefineSearch=0
The first time I had this repaired, the repairman charged me over 300 dollars. I did it myself the last time. All I used was a pair of pliers.
Jan 03, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker overflows
The Icemaker may not be dumping the cubes after they freeze then more water pours in on top of them. The icemaker has a heater which turns the cubes loose and allows them to dump. You may find someone to work on an icemaker, not sure. If this is the case, I would replace the icemaker.
Dec 16, 2008 | Amana Refrigerators
I own a GE side by side refrigerator Model GSS22KGPD WW, Serial AG225890. This the third frig of the same model with the same identical problem. The ice cube dispenser on the door only gives crushed ice...
  •  if the cubes that the icemaker makes are full size then... the water valve on the back of the machine is usually the culprit in these cases. it will not close fast enough resulting in a little overflow of water into the auger assembly every time it makes ice. it only takes a little bit of water to settle in the bottom of the pan to cause problems.
  • if the cubes are smaller than what you would expect then the water is leaking out right before it reaches the icemaker. either from the plastic tube behind the icemaker or the cup on the icemaker that funnels the water into the icemaker.
  • it also could be the timer inside the icemaker leaving the water valve on too long.
  • all these things can be tested on site. the service person must not be very well trained.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 16, 2008 | GE Refrigerators
Refrigerators Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
