My 50 inch plasma tv the color and brightess is gone
    President:
  • 1,099 Answers
This means you have lost the luminance input to the chroma decoder or final video chip. A failure of the brightness limiter may result in similar symptoms.
A few common causes are:
Check the service switch (if any). Its contacts may be dirty and moving it back and forth a few times or using contact cleaner may be all that is needed.
Check for open high value resistors around the chroma decoder IC.
Check for open high value resistors in the brightness limiter circuit.
With a scope and schematic (or even just a pinout for the chip), you should be able to trace the luminance signal to see where it is getting lost.
I have had several TVs and monitors where the delay line in the luminance circuitry has failed. Usually it's made out of glass, and inherently is fragile. Sometimes whacking the monitor would make it come back, leading to the thought of connectoritis or a cold solder joint -- where in fact it was the delay line (long rectangular unit with two to four leads). Replacing the delay line was the solution, but to check it first it'd be a good idea to look for 'in' and 'out' on the line and short the pins. The picture may be shifted, colours may not line up, but it'll tell you that it's the delay line if the picture comes back at all. It's better than looking at a saturated picture with no luminance! :)
Posted on Jun 01, 2010
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
Colored "snow" vertical line an inch thick on Samsung plasma
That is the sustain and buffer boards. Try to find a repair shop to repair on the component/board level because the cost of new boards out weighs the replacement cost.
Best Regards,
Beach TV Repair
Jul 04, 2010 | Samsung PN50A450 50 in. Plasma HDTV
Thin horizontal line,about 6 inches from bottom,is it fixable?
I am assuming it goes all the way across and is black ?
It sounds like a scan line in one of the chips inside has gone bad or needs to be resoldered. Most likely needs the board replaced by a tech.
Hope this helps
Scott
Mar 30, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
50 inch ambient light plasma
MY 2006 PHILLIPS AMBILIIGHT WONT POWER ON
50 INCH PLASMA
Jan 20, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
LG plasma tv 42 and 50 inch
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
Apr 03, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
