Question about KitchenAid KERC507 Electric Kitchen Range
KitchenAid KERC507 Electric Kitchen Range burner
KitchenAid KERC507HBT3 Electric Cooktop Range right front burner won't get red hot on high. Barely warm in any position. How do I troubleshoot and check for a faulty burner or control switch?
bigg t
  • 640 Answers
SOURCE: KITCHENAID KESS908SPW ELECTRIC RANGE
are you sure the oven doesnt need 2 voltage supplies?control voltage and load voltage.
Posted on Aug 13, 2007
the dr
  • 447 Answers
SOURCE: Range element does not work
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
  • 184 Answers
SOURCE: Kitchen Aid KESC 307 hbs4 electric range control
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Posted on Apr 04, 2008
SOURCE: My front burner not working.
Check to see that your simmer switch is in the off position, I just had the same problem and checked it back to the power connector and only had 120 V ????, I about to take the switch out and then saw the simmer switch that I never noticed. Clicked it to off and now my wife is happy again. Good Luck, hope your solution is just as easy.
Posted on Nov 30, 2008
  • 221 Answers
SOURCE: PF code on KESC300 Kitchenaid Electric Range
its a power supply problem in your unit .the PF means power failure in the unit. just check out the power cord wire it may be also faulty .or getting cut in between so the required voltage is not been supplied to the unit so its showing this pf on the display.
Posted on Jan 19, 2009
How do I take apart a KitchenAid Oven Door, Model Kerc507?
this is Kitchenmaid / Whirlpool oven door disassembling video.
Feb 25, 2012 | KitchenAid KERC507 Electric Kitchen Range
Kitchenaid kerc507 burner indicator light stays on even when turned off
That is a common problem on these. To fix it you would need to replace the burner. Folks usually wait till the burner dies since they cost so much.
Nov 30, 2010 | KitchenAid KERC507 Electric Kitchen Range
Range Ceramic Cooktop 1 burner not working
I would try replacing switch for that burner. But it also could be a defective burner.
Oct 20, 2017 | KitchenAid Kitchen Ranges
Oven wont heat up
Most likely the problem will be in the control unit. Something is stopping the relays for the oven and broiler from working.
This site has a diagram of your range and a price for the part.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=264337&diagram_id=123066#d123066
Jan 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
One of my kitchenaid cooktop burners does not work
go to searsparts.com could be switch or burner or high temp fuse under glass
Jul 02, 2009 | KitchenAid Cooktops
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
Range will not hold a consistent temperature
Good chance your bake element is out. Could be the element or a terminal burned off.
When you set to bake, normally it preheats which uses the bake and broil element.
When it reaches "near" temp, the broil goes off and the bake takes over.
If the bake element, (the one in the bottom), is not working, the temp will decline.
Check:
Turn to 450 deg.
Watch the elements, assuming you have a door with a glass, and see if both elements, top and bottom, glow red.
MrBoo aka Gary
Nov 11, 2008 | KitchenAid KERC507 Electric Kitchen Range
Oven Door Hinge is broken Kitchenaid KERC507 range
at about any appliance parts store in you area you just need your model and serial number there are links on this site kitchenaide is made by whirlpool so they can help or if you want to do it online this is good http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Jun 20, 2008 | KitchenAid KERC507 Electric Kitchen Range
Sep 25, 2007 | KitchenAid KERC507 Electric Kitchen Range
KitchenAid KERC507 Electric Kitchen Range Logo
77 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
