Question about Linksys Wireless-G WRT54G Router
My router was working and then just quit, what can I do to fix it?
  • 4,281 Answers
For that RESET your router to defaults then reoconfigure it again with below method.
First press RESET button for 10 seconds it is in back side of router.
Then all settings defaults.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 26, 2010
How do I fix Atheros wifi a How to fix Acer ES1
Have you established the router works with another device, just to rule out the obvious?
Oct 27, 2015 | Acer Computers & Internet
I have Netgear Wireless Router that has just quit. I removed the connection to tha computer and connect thr modem direct. It now works. Can this be fixed?
If the internet is working fine , after connecting the modem directly. You have already pinpointed the problem with router. There nothing much you can do, except for resting the wireless router and in 90% of the cases it starts working fine after the reset.
You can use the following link to reset the router
Reset the Router
The link also has a video tutorial for reference.
* Username = admin
* Password = password * For older devices, password = 1234
In case the problem is not resolved after the reset, its better to replace the same.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
My wireless router quit working one day the internet going in works but the router is not sending a signal how do i fix this
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 05, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cannot maintain a wireless connection.
this could be attributed by many factors, like interference. try changing wireless channels on your router. this might do the job.
Feb 14, 2010 | Linksys Wireless-G WRT54G Router
Router quite working. Wireless does not work nor
Follow this procedure :
  1. Turn off all components on your network - computer, router, modem, printers and any wifi laptops
  2. With the ethernet cable connected only between the modem and the router TURN THE POWER TO THE ROUTER ON and let it boot up.
  3. Turn on the modem and let it boot up to all lights on.
  4. Connect / boot up any and all other components on your network.
Keep this order handy in case of a power outage. Best of successes!
Dec 04, 2009 | Linksys WRT160N Wireless Router
My Linksys wrt54gc quit working. I get amber
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Thanks.
Nov 06, 2009 | Linksys WRT54GC Compact Wireless-G...
Router quit working after storm
if that router stop working by thunder storm then buy a new one.. nobody can fix it.. or maybe to go electronic shop to refer to them...
Jul 15, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
I have had a wireless dynex router for awhile and it has been working fine using wireless then when i plugged in my computer and xbox 360 to the router it has made the computers using the wireless internet...
it is getting limited or no connectivity because it is actually not connected even though it shows.the best resolution is that change your entire wireless settings and then connect all wireless devices like computer and xbox 360 again it will connect.I use to do the same when i use to work for netgear.
that will fix..
Jan 04, 2009 | Dynex DX-E401 Router
How to connect maxg with a my netgear broadband router
Try to turn off the DHCP server in the secound router, that way it'll be a swich technically, and set the secound router's fix ip address to something different, because I'm quite sure that both routers have the same 192.168.0.1 IP address and that's nogood.
Set it to anyting from 192.168.0.2 to 192.168.0.254
Nov 26, 2008 | U.S. Robotics MAXg USR5421 802.11g/b...
Wireless-G Broadband Router Failure.
Several things could be happening. 1st I need the model and manufacturer of the router. It would be helpful to know what firmware version it is using. I also need to know if you are using it wired or wireless. Then we can troubleshoot the problem.
Jan 10, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
97 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
