Question about Levelone FPS-1031 Print Server with 1 Parallel-Port Print Server
DRIVER FPS 1031
INSTALATION FPS 1031
Hi, what's the difference between bernina 1031 and bernina 1031DC?
Everything that I find calls it a Bernina 1031 DC. Even the manual to download from Bernina's website says "DC."
http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/BERNINA-manuals/BERNINA-Sewing-Systems
sewing patternreview com
Bernina 1031 Google Search
The best way to know for sure is ask a Bernina dealer.
Apr 21, 2015 | Bernina Sewing Machines
Install issue xp
uninstall the printer and do not connect the printer reinstall the printer software driver and during the install it will prompt you to connect the printer
Nov 16, 2013 | HP LASERJET PRO M1132 MFP
I have a 2005 nissina frontier. I had sensor 1 bank 1 replaced but the check eng. light still comes on with the codes 1148 and 1031
You were right in thinking if you replaced the sensor all would be fixed. But code 1148 means the sensor is not going into closed loop mode, and code 1031 means the heater in the sensor is not working.
Code 1031 could cause code 1148, and the actual problem could be in the wiring harness or the power source for the heater inside the O2 sensor.
Aug 05, 2013 | 2007 Nissan Versa 1.8 Sl Hatchback
9400 gt 512mb
Update the graphics driver to the latest version, If that doesn't help you could try completely unistalling the driver and reinstalling the latest stable version that worked well on your system.
Aug 04, 2013 | Computers & Internet
Why is my webcam 9000 doing 5 fps while it should do 30 fps? my workstation runs at 79mbps download and 75 mbps upload and it should do live webcam at 30fps but end up 5 fps with lot of pixels.
The main factors impacting fps are: CPU utilization, Power, and bandwidth. This webcam fps site describes the factors influencing fps, suggests what you can do to improve it, and provides a free method of testing it.
Aug 18, 2010 | Logitech Webcam
I need a driver for a Maxell FPS-2 Flat Speaker System
You do not need a driver for these speakers, all you have to do is plug them into the sound card on your computer. If the speaker audio cable is colored green, then you should just be able to connect it to the green plug on the back of your computer. If not, what does the audio plug/jack look like?
Jul 28, 2010 | Maxell FPS-2 Computer Speakers
Timer is on then
check the 9volt regulator
Jan 28, 2009 | JVC AV-27530 27" TV
Levelone FPS-1031 Print Server with 1 Parallel-Port Print Server Logo
159 people viewed this question
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
