Gearcase oil leak by laying on its side - Problem?
I was transporting my Kenmore stacked washer dryer model #11092962101 and had to lay on its side. There is an oil leak from the gearcase and it seems to be quite a bit.
Is this a normal situation or is it an indication some gasket is gone? Is this going to be a big problem down the line? Is there a way to replenish the oil? Or do I have to change out the gearcase totally?
Thanks in advance
There is a breather hole in the top of the gearcase. Yoy probably had some leak out through there when you laid the washer over. If it was not over to long you will probably be ok. there is no way to replenish the oil it would require replacing the gearcase.
Posted on Apr 07, 2008
  • Patrick Blasz
    Patrick Blasz Sep 13, 2014
    You can open the gear case and add oil about 1/2" below the lip. Will then have to use gasket seal when replacing lid.
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
My kenmore 98702 stacked washer/dryer washer lid does not stay open
Underneath the top unit (the dryer) there should be a spring loaded catch that holds the door open. See if it is gummed up and stuck or possibly broken off.
May 29, 2014 | Kenmore 98702 Stacked Washer/Dryer
GE model GTS22WCP can I lay it on it's side or back to transport?
it is not recommended to lay an appliance with a compressor, the reason is that the compressor oil will run to one side and the appliance will not function properly. i have heard that if laid down the make sure to stand the appliance upright for several days before plugging it in.
Aug 08, 2012 | GE GTS22WCP Top Freezer Refrigerator
Just want to know if its ok to lay my new washer on its side for 7 to 10 days while I transport it in my van its still in the box
Should be ok. It has oil in the transmission but if it is new then the oil shouldnt leak out. However I used to work in a parts dept and i have seen new transmissions that were on their sides leak out. But they werent attatched to the washer.
Nov 29, 2011 | Kenmore 24032\24036 Top Load Washer
It is not really a problem. I am wondering if I want to transport our stackable washer/dryer ...(moving it to our cottage) can it be flpped on its side? or will this do it some damage? Can it be taken...
Good Morning; Thanks for your question. The easiest way to move and transport your unit, is to separate them. Go around back of the unit. Where the top unit sits on the bottom, there are two lockdown brackets, one on the right and one on the left. Remove and save. Slide top unit back until front feet are released from front brackets. Then you can lift off. Note, it probably will take two of you for the lifting. It is best, that you not lay them on their sides. Hope this helps and have a good day.
Jan 28, 2011 | Kenmore 98702 Stacked Washer/Dryer
My washer will not spin. I believe the belt to be broken but the bottom is sealed. I cant look at it by laying unit down. How do I check this out?
first i would check your lid switch,you can test the lid switch by removing the 2 screws that hold down the control panel,some machines you need to remove the end caps of the panel to get to the screws,,,then pull the panel forward just a little and flip it back the panel has plastic hinges on top so be careful not to break them,,,then the plug going into the base is your lid switch,,unplug it and run a jumper wire across the plug and set machine on spin and see what happens. run the jumper wire to the two outside wires stay away from the green wire. if the machine spins then your switch is bad
Feb 19, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 25842 leaks has a repair manual available for Kenmore direct-drive washers for about $20. The item number is 1170635.
The back panel is not designed to come off on this model washer. The operator console comes off, but the panel along the back of the washer does not. You need to remove the exterior washer case to access the internal components.
If you have a leak, the most common cause is a worn drain pump, or leaking drain hoses, but you need to disassemble the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect your washer for leaks:
Read through the instructions provided and let me know if you need further assistance. I hope this help you.
Jan 10, 2010 | Washing Machines
Transporting a washer
Remove the top cover, and put plenty of packing down both sides to prevent the inside parts from moving about, this way it will be o/k to transport it on it's side.
Plz rate my solution.
Jan 25, 2009 | Frigidaire FTF530FS Front Load Washer
Washing Machines Logo
605 people viewed this question
Top Washing Machines Experts
