My desktop was working fine until yesterday. i unplugged the power cord from the back of tower and checked to see if some ram i ha in a differnt tower would work. i then put the cover back on tower and hooked power cord back up in back of pc.now when i turn it on it is running but nothing is going to mymonitor. its just black and says no signal. its not the monitor i checked to be sure.
  • 6,487 Answers
It seems that this is a RAM problem, try this power off the computer then take all the RAM that you have in there. Then just put the known working RAM on that computer 1 stick of RAM will do and then also double check if everything is connected fine including the cable connected to the Tower from the monitor unplug and replug it back in. Then power on the computer and check if it will be fine now and if not listen for any beep sound that you will hear then post it back here for the update.
Posted on May 26, 2010
  • 4,281 Answers
For that first try your ram in different slots of motherboard.
Pull cmos cell from motherboard for 10 minutes then refix it.
Make sure motherboard is not ground with cabinet.
Reconnect processor and it's fan.
Reconnect pci or vga card if any.
Reconnect both connection to harddrive.
Clean dust from all parts.
Try reconnecting ram 4 to 5times then it will work again.
Let me know if you need further assistance.
Thanks for using FixYa.
  • 1 more comment
  • missydb39 May 26, 2010
    WHERE IS THE CMOS CELL AT OR WHAT DOES IT LOOK LIKE?
  • Cmos cell i round cell on motherboard .
    For that you need to open cpu cabinet .
    It looks like below image.
    http://ramanathan.files.wordpress.com/20..." target="_blank" rel="nofollow" >click here
  • check num lock led on key board when you turn on the computer if your num lock led is on and off when you press num lock key then cpu is working fine.
    Then when you press power button of computer press F8 key untill you see safe mode and other menu then enter in "Enable vga mode " and change screen resolution to 1024*768 in display settings.
    But if num lock led is constant then you need to check above in cpu cabinet.
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My computer screen is black after logging in and i cant do anything i have windows vista
    Hello
    This usually occurs when your RAM is faulty and can actually happen to all computers running many different operating systems. Aside from installing a new operating system to test out the RAM, you can simply switch out your RAM.
    Turn off your computer if it is on. If you are experiencing the black screen regularly, there is a good chance that it will not allow you to boot up your computer fully without shutting itself down. If this is the case, your computer is already more than likely off. Remove the power cord from the computer tower.
    Remove the screws that hold the PC tower cover in place with a screwdriver. The tower cover usually only comes off on one side, so gently remove the side that is capable, and place it away from the tower. Users with laptops need to remove the RAM panel from the underside of the computer. This gives you access to the RAM for replacing.
    Locate the RAM that is attached to the motherboard of your computer. You will see clasps that hold the RAM into place, and you may see more than one stick of RAM. Remove all of the RAM sticks by pushing the clasps away, unhooking the RAM from the motherboard. Click your new, replacement RAM into place, and cover the tower back up with the cover, or replace the laptop RAM panel.
    Hook up the power cable or place the battery back in, and power on your computer. You now see that your computer is working without the black screen appearing. If you have more than one stick of RAM, turn the computer off, and remove the power cords and battery. Insert one old RAM stick, and cover the tower back up, replace the power cord or battery, and turn on your computer. Check to make sure it does not present you with the blue screen. One by one, reinsert the old RAM sticks into your computer, and test your computer for stability. Once you are presented with the black screen, remove the last old RAM stick that you inserted, and your screen problems are gone.
    Nov 14, 2010 | Computers & Internet
    HP a1050y....Push the button to turn it on, and
    You might have a bad power supply, or something might have loosened inside the case. sometimes if the memory or processor get jarred , they might need to be reseated. unplug all the cables from the back of the tower, only leave the power cord in then try to power up. Sounds like it might be power supply or Maybee the motherboard. Have a computer tech check all the inside connections. Good luck..
    Mar 31, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
    Sony VAIO RB30C (VGCRB30) PC Desktop Won't Turn On After reinstalling ram
    Unplug the tower
    Remove the ram and turn the tower on wait till it give you fast beeps. (telling you no RAM)
    once that happens shut the system down by unplugging it again
    Re-install your RAM and try to boot again
    May 26, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
    Power/Startup Fail
    There may be problem with some wire connections or RAM is loose in the slot. insure that RAM is perfectly tight in the slots.
    Jan 03, 2009 | Computers & Internet
    Tower intermittently loses power
    you need a new power supply !!!!
    Jul 05, 2008 | HP Pavilion 754n PC Desktop
    HHHHHEEEELLLLPPP!!!!!!!
    take that memory card out.. KILL the bios. place the jumper next to the battery from position 1-2 to 2-3 .. attempt to turn the machine 2-3 times.. put the jumper back, turn the pc back on.
    you probably have a bad memory stick.
    Jun 16, 2008 | HP Pavilion A1050y (PU131AV) PC Desktop
    Power Switch trouble
    Hi, I have seen this problem before and it was related to circuit failure, let us hope this is not the case! From your posting I understand that your computer won't turn on now. So the next step is to reseat the components inside the tower. The first thing you need to check is the connection from the switch to the mainboard. Open up the case and follow the swith wires to the main board. They should be blue and white wrap around each other.If the connection looks fine then disconnect it and then reconnect it. Try the power the computer on. If it doesn't come on then we will need to do the next step. Open up the case and remove the RAM and place it back in, then diconnect the hard drive and reconnect it. Then disconnect the powersupply from all everything including the mainboard and then replace it. Then try to power it on. If you need help with any step of this posting feel free to start a live chat with me and i'll walk you through it. Let me know how it goes. Good Luck
    Sep 28, 2007 | HP Pavilion a450n PC Desktop
    Computers & Internet Logo
    David Payne
    David Payne
