Question about Watches
Can't figure out how to pop the pins on the bracelet to shorten the wristband.
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details.
Thanks for using FixYa.
Posted on Jun 03, 2010
I want to remove links on my wristband.
Most wristband links are held together with screws or pins. Screws are usually only found only in high end watches so you most likely will have to remove pins. Without the proper tools and know how you will most likely scratch the bracelet or, worse, damage the pins. A jeweler can do this for you easily and, if they even bother to charge you, it shouldn't be more than $5. Should you wish to proceed on your own, you can buy the specialized tools on ebay quite reasonably.
Apr 10, 2010 | Armitron Two Tone Sports Watch
How to shorten the watch band without breaking it
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Apr 09, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
Can not figure out how to remove links from Casio watch band
Job done!
Apr 01, 2009 | Casio LWQ120DA 7AV Atomic Executive Wave...
How do I shorten the watch band?
Job done!
Mar 28, 2009 | Watches
How to shorten a wrist banc for a TB4008 watch
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
Jan 09, 2009 | Tommy Bahama Island Palm 2 Tone Link Watch...
Tighten wristband of the Nixon Watch , remove links
Job done!
Jan 05, 2009 | Nixon Manual NIX0031 Wrist Watch
Shortening stainless band for 1st generation Tissot Le Locle
Job done!
Jan 04, 2009 | Tissot Le Locle Automatic Chrono Large...
Shorten movado wristband
There is nothing you can do yourself as the special equipment is needed.
Find your nearest watchmaker and ask to shorten your bracelet.
Dec 18, 2008 | Movado 0605068 Wrist Watch
Wristband too big
Job done!
Dec 02, 2008 | Kenneth Cole KC1104 Wrist Watch
Watches Logo
23 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
