Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Chain saw won't start - pull starter pulley hard to pull?
  • AyeAye May 26, 2010
    Took the spark plug off and pulley works like normal - but when the spark plug was reinstalled, it was hard to pull again. Would that be the diaphram needs to be replaced? Where can I get the part?
  • 196 Answers
If it worked fine the last time you used it, then pull the spark plug and try pulling the rope. See if it's easier or if gas shoots out of the plug hole. I've seen this happen when the diaphram in the carb goes bad from sitting over winter. It loads up the cylider with fuel and makes it very difficult to pull the rope. If there is no fuel in the cyliner and it's still hard to pull, make sure there is nothing binding the clutch/sprocket. I've had chucks of wook lodged in there that caused it to bind the crank output, which resulted in a hard pull on the rope as well.
Posted on May 26, 2010
2 Suggested Answers
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Feb 20, 2013 | Husqvarna Chain Saw Models 51, 55
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan 14" chain saw has become difficult to
If you have more questions or need additional help pleasereply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa. gif,gif89a%12%00%12%00%b3%00%00%ff%ff%ff%f7%f7%ef%cc%cc%cc%bd%be%bd%99%99%99zyzrur%00%00%00%fe%01%02%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%21%f9%04%04%14%00%ff%00%2c%00%00%00%00%12%00%12%00%00%04x0%c8i%2b%1d8%eb%3d%e4%00%60%28%8a%85%17%0ag*%8c%40%19%7c%00j%08%c4%b1%92%26z%c76%fe%02%07%c2%89v%f0%7dz%c3b%c8u%14%82v5%23o%a7%13%19l%bcy-%25%7d%a6l%df%d0%f5%c7%02%85%5b%d82%90%cbt%87%d8i7%88y%a8%db%efx%8b%de%12%01%00%3b
Jan 09, 2011 | Poulan 14" Chainsaw
Can't restart my new husqvarna 450 chain saw after a little bit of time using it. i followed the instruction manual both times.
The manual may not be clear, read warm line 3 below, read it again. The 450 manual I read says something similar under warm start. Are you opening the choke after turning on the ignition? Before pulling the starter rope? Flooding is the most common hard start problem with 2-cycle engines. If you are opening the choke I recommend you contact Husqvarna for guidance. They will likely send you to a neighborhood dealer, gratis.
HusqvarnaUSA.com/ContactUs
http://www.husqvarna.com/us/homeowner/support/customer-support/
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Feb 28, 2010 | Husqvarna 450 e-series 18" Chain Saw
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
The pull cord will not retract back into the saw. When I tried to start the saw, I pulled the cord and now it did not retract back. It is all the way out and will not recoil.
When I have had this happen it means that you need to manually rewind the cord and put some additional tension on the take up pulley. To do this you'll have to open the saw up and untie the handle. Turn the pulley like one turn, put the rope back through the hole and tie the handle back on. All this is done while maintaining tension on the rope.
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Nov 15, 2009 | McCulloch Garden
Recoil spring on homelite chain saw doesn't retract pull rope
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw hard to pull
check starter pulley .it may be warped and hard to pull under compression .also if chain is very tight it can put pressure on crank and cause hard to pull
Nov 09, 2008 | Garden
Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Oct 03, 2008 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
1,400 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
