Question about Vacuums
Panasonic Vacuum MC-E450UK
Am trying to gain access to the mains switch as the cable is inter-disc. and cuts off the power. Pnasonic Vacuum MC-E450UK trying to remove cover for access to switch.
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Posted on Jul 22, 2010
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Panasonic Vacuums – MC-E450UK
I’m trying to gain access to the mains switch as the cable is inter-disc. And cuts off the power. Panasonic Vacuum MC-E450UK trying to remove cover for access to switch. I’m trying to gain access to the mains switch as the cable is inter-disc. And cuts off the power. Panasonic Vacuum MC-E450UK trying to remove cover for access to switch.
Trying to remove the cover to access the switch is most of the vacuums you can access the motor assm that is connected to the switch by un-screwing the cover to access the switch, or to check to see if the are clips that are holding the item, or contact the website for Panasonic.com and ask for a schematic of the vacuum and that will give you and exploded view of the way the vacuum is put together and by that you can see how to replace the switch.
http://www.vacuumcleanershop.com/panasonicpopup.htm?WCW=GOOGLE&gclid=CPvAoIHdyZICFQKwPAodYiunMA
Posted on Apr 08, 2008
Panasonic Vacuum MC-V7395 to replace the foot release pedal do I have to remove the belt and other things to get to it?
On most of the uprights I have worked on, the top cover has to be removed to get access to the release mechanism at the rear.
Apr 26, 2016 | Panasonic MC-V7395 Vacuum
How do I change cable on Panasonic vacuum MC-E3003?
I wasn't able to find any answers/directions, but I did find the schematics on a parts website. Hopefully this might help you.
25398048-lp0tniytl1tz05r5qe5dhgvc-5-1.jpg You should be able to save the picture to your computer and then blow it up to see it better. I found it at the link below. You can try viewing it bigger there:
Panasonic MC E3003 Vacuum Cleaner Floorcare Parts
Feb 03, 2015 | Panasonic Vacuums
Hi, I have Pnasonic Vacuum cleaner MC-7650 -2000W,while working machine stops its own.I tried all the way ,all in vain
If it operates less than 15 minutes suspect the filter is blocked and that will cause the motor to heat triggering shut off.
l have seen this and the filter may be washable or not.
Dec 04, 2012 | Panasonic Vacuums
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
Panasonic MC-CL673 vacuum is not getting up to speed and smells
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Jim
Nov 29, 2009 | Panasonic Vacuums
How to rewire a panasonic vacuum cleaner
Once you have taken the handle off and the front plastic cover below the handle at the front and above the bag/bucket holder, you gain access into the power cable and switch connections.
One wire will disconnect easily, the other won't, so instead of trying take this wire out of its connection where many others are from the switch and the motor, cut it on the mains lead before it enters the connection and reconnect the new mains lead wire with a **** or block connector, the other should connect normally with a spade connecter,making sure its will take the amperage of the v/cleaner
Hope this makes sense!
Sep 18, 2009 | Vacuums
Removing cover to motor
You will have to access the motor by removing the entire bottom brush housing and tilting the vac motor shaft out of the housing. Once released you will have a main body and brush housing.
There are visible motor housing screws in the lower portion of the main housing and if I recall there may be twoscrews inside the bag chamber as well
Sep 09, 2009 | Panasonic MC-V5209 Vacuum
Won't come on
Sorry, but the direct answer to your question is: no, there is no reset switch on this machine. What you do next depends to some extent upon what part of the world you are in. You should check that there is power to the electrical socket you are using (plug something else in and try it). If you are in the UK you should check the fuse in the plug (if this has blown you will need to find out why). Quite often the problem is simply a break in the cable. Beyond that you will probably need professional hands-on help.
Apr 08, 2009 | Panasonic MC-V5737 Bagged Upright Vacuum
Trying to replace the mains cable on uproght cleaner mc e468,but having great trouble getting the plastic covers off
first remove handle
single screw rear of cleaner and slide handle horizontally rearwards
remove access cover (2 screws) for electrical connections and switch
Aug 09, 2008 | Panasonic Vacuums
Lights are on but motor won't run?
I had the same problem, and i found this is the user guide: problem: Tripped circuit breaker/blown fuse at household service panel. Solution: Reset circuit breaker or replace fuse so, i've replaced the fuse (my friend did) and it solved it.
Sep 14, 2005 | Panasonic MC-V5005 Bagged Upright Vacuum
Vacuums Logo
317 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
