Question about Kohler Electrical Supplies
1975, 7.5 Kohler marine genset, runs only with the reset depresed
I have a 1975, 7.5 Kohler marine genset. it runs fine when i push in the reset button on the control section of the generator. The motor is fine and it seems to be generating power, it just won't keep running. It ran great all last summer every Sunday evening for about 4 hours but at spring startup it won't keep running. What I would really like is a service/trouble shooting manual for the generator control end. i have manuals for the engine end.
thanks
gary
  • 905 Answers
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
Posted on Jun 12, 2010
Generator starts but won't keep running
what are the fault indicators showing, over voltage, frequency wrong charging fault ?
Feb 11, 2015 | Kohler 13EGD 13kW Gasoline Marine Genset
What does the code OU on a 23EOZD marine generator mean
are you sure thats not OV cus thats over volt !! that means the output voltage had or still does excede the normal voltage , i had seen this happen to folks before if they dont kill there genset before they connect to shore power
Aug 26, 2014 | Kohler 23EOZD, 23KW-60Hz
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
My 3.5 kw kohler marine gen starts and shuts right off throwing code uu (under voltage) last season it did this and sometimes showed loc (loss of coolant) but never appeared low or showed sign of coolant...
Check that when you run it, it is not in fact making correct voltage (within about 10% is good), also make sure the engine is coming up to full speed, 3600 or 1800. You could check this with a multimeter that measure hertz. On the main output leads when the genset is running make sure it is getting close to 60 hz. or if you are in an area that uses 50 hz. check for that respectively. There are a couple things that would affect this, one would be your SCR module. There is a test procedure for this which you could find here. http://www.scribd.com/doc/50171916/tp6196-1 . I don't work on marine units, mostly standby so these manuals are for residential. Check your fuses, could even go as far as checking the wiring in the back and wiring and condition of the brushes and sliprings. These actually build field voltage to make 240 or 120 volts whatever your unit is configured to make. The brushes need to sit flat on the slip rings and on a unit with 10 hrs. the sliprings I can't imagine would be very dirty but check that as well. If you have an ADC2100 controller use this manual to go into the controller to verify that it is set for the correct voltage that the machine is built to make. The only other fairly simple thing to check that I've had issues with is if Kohler mounted a fuse block on the side of the cabinet mounted to the genset with no vibration isolation. Check these fuses while attempting to run the unit and make sure you getting steady voltage out of them as sometimes they will vibrate causing pulsed voltage to come out of them and can give you an intermittent UU, UF, or OC fault (undervoltage, underfrequency, overcrank).
Jul 13, 2011 | Kohler 12 kW Emergency Power System -...
My SW 3000 Invert/Charger works fine at the dock on shore power but will not charge or let the AC pass through the unit on my Genset. The genset runs everything else on the vessel including a 19000 BTU Air...
I have the same problem but on an intermittent basis. The first time it happened the tech suggested resetting the default settings and it came on immediately. However the problem has been reoccuring from time to time and I now have no confidence in my one month old unit.
ghart69499@cs.com
Feb 19, 2011 | Xantrex Technology Heart Freedom 30...
I have a kohler 5E marine generator It will blow the input fuse when cranking. If the voltage regulator is disconnected it will start but only run if the start switch is pressed. Any Ideas?
I have the same genset. Just fixed a similar prob with it. Mine would intermittently blow fuses at first then started blowing them as soon as trying to start. I also saw a puff of smoke from reg when it did run at one point. Carefully check stator wires for shorts to ground. Make sure to lift the stator wires that are grounded in control box. If no grounds replace control board and reg board. $400+. Cross your fingers and try it. Mine worked, thank God. The pc boards are marginally designed and built. The relays, diodes and other componants are way too undersized for the application and can not survive a lot of cycling
on and off. When starting genset make sure to slowly apply loads to it. Same thing when shutting it down. Dont shut it down with any load. It wont take it
Good luck
Feb 15, 2011 | Electrical Supplies
I have a Kohler 12RES, 12.5kw genset. Less than a
check connections on speedsensor or take down rpms must be a screw or bolt on de fuelpump
Jan 25, 2010 | Kohler 12 kW Emergency Power System -...
Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
Apr 20, 2009 | Electrical Supplies
Electrical Supplies Logo
734 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
