Question about HP Compaq Motherboard
I cannot get com port 2 to work. I am adding the second com port the mother board is suppose to support 2. I have found the connection connected the 9 pin connector looked in the bios for port b but it is not there. AT WITS END... Its a hp compaq d330 st.
  • Jaye Ellen Burke
    Jaye Ellen Burke May 26, 2010
    Are the Configuration switches on this second Comm port? The Mother Board does come with two Serial Ports, each with kits own connector on the back panel of the computer. Make sure you are not confusing COM1 and COM2 connectors. Do you want to add ports beyond COM2?
    Genius:
  • 1,027 Answers
The Bios selection should be in 'advanced' features that allows the selection for the com ports. If the option is greyed out, then it is not available for use.
Posted on May 27, 2010
Printer goes offf line
1. Check USB cable.
2. Check connections between system & printer
3. connect this printer to another system & observe new hard ware found? if not, problem with printer port or mother board, replace it.. If yes check system side.
Jan 06, 2013 | HP Office Equipment & Supplies
My mother board gigabit 61pme s2p series mother board.with amd althon 3ghz processor.the problem is when i connect the usb pendrive to back of the usb port...if i send data 1 or 2gb data to pen drive.the...
your problem is kind of complicated. Check if you have a defective usb flash drive or an usb connector by doing so:
  1. Try other usb flash drive. If it solves the problem you have a defective flash drive
  2. Try to plug in to other usb port. Observe each port. If you see that you have a problem with your usb ports, buy a new usb port card
Aug 01, 2011 | Intel Motherboard
My usb ports do not working.When I put my mouse in it, the mouse lights become on but in the desktop the pointer is on its place and no hardware are found.I check 3 more mouse and key boards but the...
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have added one expansion board to the mother board to enable more telephone extensions. (The manual is vague about this procedure) When I plug the ribbon cable into the mother board, the enhtire system...
Yep, the manual is extremely thin when it talks about adding the expansion cards. Check that connection. You either have bent/broken pins, the cable plugged in wrong, or a bad expansion board.
The board plugs into the top port on the cabinet, but you might also try plugging it inot the bottom and see if it kills the system. If it does, I'd be leaning toward a bad board.
Carl
Sep 23, 2009 | Samsung Prostar 816 Phone
I have intel 102 GGC mother board with dual core as processor....
go to this site www.crucial.com and scan your system. It will tell you what you have and how much more can be added.
Hope this works for you
Mar 16, 2009 | Computers & Internet
Upgrading two USB ports on front panel
Hi..
there is no such converter..
those pins should connected to ur mother board only...
once check ur bios settings..
or
use external usb hub..so u can get multiple usb ports that u need...
Jan 01, 2009 | HP Pavilion 761n PC Desktop
Drive cable connection
Its easy to connect. Try the followings:
1) See the IDE0 port on your mother board and make connection for your hardisk to this port.
2) See the IDE1 port on your mother board and make connection for your CD-ROM to this port.
3) The IDE for floppy is much smaller than IDE0 and IDE1 so you can easily figure out that port and connect your Floppy Drive to that port.
Note: If you are newbiz then keep attention when connecting the cable to the device. Please push gently and firmly. If it got set easily then you are on right way, otherwise try in other direction.
Thanks
Iqbal
Mar 09, 2008 | Compaq Presario 5000 PC Desktop
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
How to connect two monitors with one system unit
You will need a video card that has more than 1 head ( output ports), and a software program that will let you do this with windows can be found here or here.
Nov 10, 2007 | Computers & Internet
HP Compaq Motherboard Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
