Question about Zenith H27F56S 27" TV
How do I adjust the brightness on my Tv - Zenith H27F56S 27" TV
I have a Samsung 55in curved TV. It has auto dimming. In the evening with the lights out it dims to where it is difficult to see the picture. Can I get rid of the auto dimming?
If the brightness on your TV changes automatically (randomly dims and brightens), you may need to adjust the:
  • Eco Sensor function.
  • - And / Or -
    • Energy Saving function.
    The Eco Sensor and Energy Saving functions adjust the brightness of the TV to reduce power consumption.
    • When you set the Energy Saving function to Auto, the TV changes its brightness automatically depending on what you are watching on the TV.
    • When you set the Eco Sensor to On, the TV changes its brightness automatically depending on the brightness of the room.
Oct 18, 2015 | Samsung Televison & Video
How to adjust brightness
You can adjust the brightness in the TV menu using the TV remote control. Look for picture options.
Jul 20, 2014 | Toshiba 15VL56 15 in LCD TV
I have a Studio 42" rear projection tv, The picture is incredibly bright, have tried to adjust the brightness but it doesn't help....can anyone help me?
I believe these were made by Samsung. You will need to search for a service manual for more specific information.
May 16, 2014 | Orion STV2763 27" TV
Brightness adjustment
There will be a control panel on the TV, usually on the side of the TV. You can use these buttons to enter the menu and adjust picture brightness. You can find an inexpensive universal remote easily.
Nov 04, 2013 | Sharp Aquos Televison & Video
SAMSUNG LCD TV very bright screen
hi Elle924.
this is all i could find out.
What kind of panel do you have - a LED or CCFL one? If it's CCFL then check the inverter board. The main board might be fine (changing the brightness settings changes the signal to the inverter board) but if the inverter board is faulty somewhere then the problem you described may be caused by it
or try this forum.
Why is my tv extremely bright Solved Other Consumer Electronics
or this one might help you.
White too bright in picture on Samsung LCD TV Forums
or even this link.
SAMSUNG LCD TV very bright screen Google Search
Nov 28, 2017 | Televison & Video
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
Sylvania tv srt2232s picture is dark. i have used the remote gone to pictureand still unable to adjust brightness. need your help to adjust brightness. What do i need to do to change the brightness
Hi
Remove back fron tv locate line flyback transformer
on this transformer there should be two adjustment controls very carfully adjust the bottom one, do not adjust to far as picture will have fine white lines on it
May 17, 2010 | Sylvania SRT2232S 32" TV
Adjusting visuals on the TV does nothing
This problem may have been coming from the Flyback Transfromer or the Tippler, you have to be a technician to adjust that! if you are, well first thing is to put the TV ON and sent up all the level to max for the brightness & Contrast, then after try to adjust the Flyback screen voltage for hi bright, if it work there, try back now to see if you are getting any control of the menu of brightness & contrast to work! please be careful, there about 28K volts to 35K volts, this can kill anyone... IF YOU ARE NOT A TECHNICIAN PLEASE DO NOT OPEN THIS TV.... RandyXi CriticaL PaniX
Jun 29, 2007 | Sharp 55R-WP4H 55" Rear Projection...
Zenith H27F56S 27" TV Logo
44 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
