Question about Refrigerators
I have a ge model pfs22sisbss that is not cooling effectively. i have cleaned the evep coil thoroughly and surounding area thoroughly. This has not helped. i see thar the fan next to coil revolves very slowly. i can almost count the revolutions, is my problem... i need a new fan?
  • 1,284 Answers
Hi, you have rightly identify the cause of the problem, you need to change the fan...
Take care
Posted on May 26, 2010
  • 3 more comments
  • g_futures May 26, 2010
    do i need a new control board with new fan....i read in your probleem reviews that this might be necessary
  • Shehu Pro
    Shehu Pro May 26, 2010
    Well, you might probably need a new control board, but you have find out first if the present one is bad before you get a new one..
    sir: must i replace control board as well...i read in one of the fixya histories that this might be necessary
    thanks....i am not used to this format...i asked the same question twice..appreciate info ...bye
  • Shehu Pro
    Alright, don't forget to accept and rate the solution...
Why is my GE Monogram, model zfsb26dnd SS, emitting an odor from the front bottom behind the base grill. The air blowing from underneath produces the smell when the fan is operating. The odor appears
The coil underneath the refrigerator, called the condenser coil, is probably blocked with dirt. This causes undue heat on that coil and the dirt stinks. The condenser coil must be cleaned thoroughly.
Dec 10, 2014 | GE Refrigerators
My GE Profile Refrigerator (model PDS20MBSBB) is making a clicking noise. The thermostat display turns off while this happens. When it comes back on the fridge gets really cold and then slowly gets
needs new control board wr55x10942. condensing fan not running or running slow. it get to hot then the compressor relay cut off compressor to protect it once cooled down enough it starts back running.
Oct 09, 2014 | GE Refrigerators
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Our GE unit pfs22sisbss over under stainless steel refrigerator is not cooling...in both areas. This happened once before and we believed it could have been from the kids leaving the door open. We...
Try switch off the unit and leave it for a day with the doors open, that will defrost the unit fully and switch it on again. Remember not to open the door for at least 12 hrs. to let the unit time to cool down.
May 24, 2009 | Refrigerators
Quits cooling on hot humid days
The evaporator coil is not getting cold enough to draw the humidity out. You may need to clean the indoor and outdoor coils thoroughly. If the unit still isn't cooling right, it is probably due to a refrigerant leak in the system. You will have to to have the unit looked at by a professional if there is a leak. Leaks can be very difficult to find and very costly. Most of the time, it is more cost effective to replace it if necessary.
Mar 31, 2009 | Dometic Rooftop RV Air Conditioner
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
