Question about Whirlpool Dryers
My dryer is giving off outside heat and not drying my clothes
  • 20 Answers
Check the filter is clear and the access vent from heater fan to tumbler is not blocked - have seen a sock blocking air flow -
drier is only a fan blowing air over a heated element & through a duct or pipe into the tumbler - on exit the air passes a filter and if this is blocked - through passage is obstructed and hot air will escape backwards
Posted on May 26, 2010
My 1993 Maytag Clothes Dryer heats up, turns but does not dry the clothes unless I place an absorbent towel in with the items. It sweats water from the bottom of the dryer. What is going on?
To dry clothes, we need 2 things:
1-heat to evaporate the water from the clothing
2- adequate air flow to exhaust the moist air, thereby drying them.
Your heat seems to work.....if you stop the dryer mid-cycle, the clothes should be hot.
It sounds to me like you have a lack of air flow through the dryer. If you can get to the exhaust vent grill outside, then see if you get a large volume of air coming out of it. If not, then look for the louvers stuck closed on your outside grill, or any kind of blockage in your ductwork.
Perhaps undo the vent at the back of the dryer TEMPORARILY
Mar 20, 2013 | Maytag Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Tumbler has heat but clothes not drying
You may have lint issue with the vent hose. If your vent hose has alot of lint in it the dryer will not properly dry clothes. Clear it out really good, take it outside and shake it all out so that its as clean as you can get it and then give it a shot. If it still isnt drying at that point you may have to replace the thermal fuse which regulates the temperature inside the dryer.
Dec 13, 2009 | Whirlpool Dryers
Dryer will not dry clothes after 60 minutes in the dryer clothes still wet just like they had just come out of the washer.
The reason you are not getting the cloths dry after 60 minutes and are just as wet is airflow or rather the lack thereof.
First verify that you dryer is actually starting, (I know... you're thinking, duh!) but simple things first. Let the dryer run on high heat for about 2 minutes and open the door. See if there's actually heat coming out of the door. If there is, that's a good sign. Did the drum seem to be tumbling? if yes, this also is a good sign.
Next turn the dryer to fluff/no heat and turn it on. Go outside and check the dryer vent (if possible) and see if there is a reasonable amount of airflow coming out. Most likely it will be weak (since your cloths aren't drying.) Now that you have checked that, go inside, disconnect the dryer hose on the back of the dryer. Compare the airflow from the outside vent. If it is considerably stronger than outside, your ducting needs cleaned. If it is about the same and still weak, something is blocking airflow in your dryer.
Here's a decision point. If you feel you don't want to try to fix the dryer yourself, get someone qualified or take it to a qualified maintenance shot for the dryer. If you feel up to the task, FIRST unplug the dryer, then you'll have to disassemble the dryer (can't give you specifics without the model number) and find the clog and remove it. Once the clog is removed (very likely lots of lint and maybe even a sock or two) reassemble the dryer, hook the vent hose back up, plug it in, try to dry your cloths.
Hope that helps
Nov 14, 2009 | Whirlpool Dryers
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
