Question about Maytag MDC4650AW Built-in Dishwasher
Soap dispenser door pops open
I put my detergent cube into the soap dispenser and right after the cycle starts, the door pops open and the cube ends up on the bottom of the dishwasher. Is there anyway I can fix the dispenser or do I need to have a serviceman come out?
  • 901 Answers
Try cleaning the compartment. If the latching is not OK, it could be a latch problem, or alignment, or total dispenser. Contact service provider for assistance.
Posted on May 27, 2010
The soap dispenser only closes after several tries. At the end of the cycle, the soap is wet and stuck in the open dispenser
May want to try liquid detergent instead. Sometimes using too much detergent will prevent the dispenser from opening and then the soap turns into a wet glob in the dispenser.
Mar 15, 2016 | Dishwashers
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
My FRigidaire GLD2250RDC6 dispenser cup doesnt open after any full cycle. Open the cup manually & the soap cube is still there.
remove door face so you can see the back side of soap door. close soap door and turn timer by hand. watch and see if a part on the trip mechenism is broke.. then replace that part
May 26, 2012 | Frigidaire Dishwashers
The soap dispenser at times does not open during the wash cycle. When the cycle is complete and the front door is opened the soap dispenser is either stil closed or at time is open with the soap still...
Check the way you're loading your dishwasher. Sometimes large plates or baking pans can block the door of the dispenser. The latch unlocks but because the door is blocked, the detergent can't get out. Once you open the main door, the dispenser door may pop open and looks as if it has been in the fully opened position when it was actually held in place by that large utensil!Cutting boards are major blockers as well.
I hope this helps. If it does, please come back to fixya and rate my answer
Jun 30, 2011 | Jenn-Air 24 in. JDB1250 Built-in...
Powdered soap residue (cascade) sticks in the dispenser after dishwasher has completed wash cycle. I have tried the new gel pacs and they also seem to stick to the dispenser even after the the dispenser...
The best solution is to use the compressed powder cubes, the will fall to the bottom of the dishwasher as soon as the soap cup opens. New dishwashers use so little water that they dont do a good job of getting all the phosphate free detergent out of the cup. The cubes work fine and you will have no more residue
Jan 25, 2011 | GE Dishwashers
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Dec 05, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Soap dipenser
Try this... Wipe out the soap dish with white vinegar and a soft cloth.. make sure you get everything off the edges of the door and look for any nicks, blemishes or deformation of the dispenser door to make sure it is not mechanically binding up when it is cycled open. If Ok.. then.. clean your drain filter.. then.. start a wash cycle using the hottest setting ( without any dishes) .. and after about 10 minutes or so.. stop the process and open the door and add in 2 cups of white vinegar.. Let it complete the wash cycle.. When complete..try running a dishless cycle on any setting with detergent ( use about 1/3 less than you usually use) and see if that dispense adequately. If that works, then the next time you load the washer. make sure you don't have anything up against or limiting the door from opening. Hope this helps..
Sep 23, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Maytag MDC4650AW Built-in Dishwasher Logo
216 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
