Question about Fisher and Paykel IWL12 Top Load Washer
The water in my washing machine is not draining. How can I fix this problem??
CHeck the impeller underneath the machine is not blokced by a sock, clothes peg or dust bunnies - reach underneath and you will feel a 6 bladed fan about the size of a bathplug. This is what drives the pump that empties the machine. Give it a little spin with your fingers and it should start to empty out again
Posted on May 27, 2010
    Problem Solver:
  • 17 Answers
Check the drain hose (water outlet) to see that it is not kinked to stop up the flow.
Posted on May 26, 2010
  • 1294 Answers
SOURCE: Washing machine fills with water when not in use.
Click on washing machines above, (below FIXYA) on this site, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site. You have to replace your inlet water valves. Its simple.
Posted on Feb 11, 2008
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
mumma_1
  • 903 Answers
SOURCE: washing machine problem
it could be that the carbon brushes need changing on the motor. you can drain the machine if there is water in it by disconnecting the outflow pipe from the u-bend under the sink and lowering it into a bucket. This will empty any water in the machine (most of it any way), at the same time you can check for blockages in the outflow pipe while it is disconnected. If the machine is at least five years old then the carbon brushes are easy enough to change yourself, they are seated each side of the motor which will be on top of the machine. Simply carfully disconnect the electric cables on each carbon brush, gently slide them out and replace them by carefully sliding the new ones back into place and then connecting the electric cables again. The carbon brushes for hotpoints were universal for the older models 5 years old or more, but the newer version have cleverly put the motors on the bottom and are hard if not impossible to get to. You will then need to call out an engineer. Always make sure that you disconnet from the mains before touching anything within the machine, and if you are not confident in what you are doing the don't do it, call an engineer.
Posted on Oct 23, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
Posted on Jan 26, 2009
  • 127 Answers
SOURCE: Washing machine will not drain all the water. If
there is always a little water left in the drum assembly when done pumping. however it is usually well below the level of the clothes basket/drum so that there is none contacting the clothes when at rest.
if you can actually visibly see water within the clothes basket/drum when the cycle is complete, then check below.
have you lengthened the drain hose beyond the standard length to reach to your taller than normal sewer/drain inlet??? if so then you're getting more water returning to the unit when the pump shuts off and if the extra hose is long enough then theres enough water returning to your tub so that the basket sits in water at rest..
if so you'll need to install a check valve to keep the additional water from going backwards into your unit. some of these units have one built into the drain hose where it connects to the pump.. i tried looking yours up via the model # listed on the 1st page but got nowhere with that number.
you could also have a restriction in your pump or drain assembly that may be slowing things down some.. can't be of more help without proper model # though..
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
E5 error on Onida washing machine Need solution
5E. This means the washing machine has a "water drain error". It's basically timed out on empty, it's tried draining out the water for 10 minutes and the water level still hasn't fallen below a specified level (or at least it thinks it hasn't). This error should be reset by pressing the Start/Pause button though if there is a fault it will need fixing or the error will just return.
A washing machine not emptying the water can have various causes as can a washing machine thinking it hasn't drained the water because it's possible that the signal telling the machine that the water has gone can sometimes not be triggered if a fault in the pressure system prevents it.
To troubleshoot this problem the first thing to check is the pump filter, which could be blocked. I have extensive advice on diagnosing pump faults here Washing machine won't drain water (stuck full of water) ' Faults on pressure system
May 17, 2015 | Washing Machines
I have Kenmore elite washing machine model: 11045088401. It started leaking water from the drain pump. How would I fix it?
If u have seen the water leaking from the pump the only fix is to replace the pump..
Dec 13, 2012 | Washing Machines
May tag washer doesn't drain water
the water pump must be brocken you should call in a specialist or try to fix it or you could try to fix it yourself this site might help http://washer-dryer.hubpages.com/hub/washing-machine-not-draining
Feb 01, 2012 | Maytag Washing Machines
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine not draining water during washes
hi..The problem most probably is your pump is not working
or the hose that the water drains out is blocked.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Washing Machines
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
You have an open solenoid on your water valve where the fill hoses connect. Change the water valve and you should be good.
Jul 25, 2008 | Washing Machines
Fisher and Paykel IWL12 Top Load Washer Logo
210 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
