Question about Philips 42PFL3403 42 in. TV
Hi, Currently i have a Philips 42PFL3403. when i connect to my laptop(HP ELITEBOOK 6930P) WITH vga connection, I can only get the desktop wallpaper on the TV, but no icons or whatso ever. tried all from dispaly setting.... 1.currently tv mode is set to 1280*1024 60hz. laptop 1440*900 60hz>>no-go. 2. Window mobility settings did not work either. 3. choose the extended the desktop onto this monitor-no go.
SOURCE: Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Posted on May 05, 2008
SOURCE: Trying to connect PC to Philips LCD HDTV
While the tv is on the right input, and the computer is running, try unhooking the cable and hooking it back in. That's the only way I can get my Philips to detect the HDMI signal from my pc. I haven't found a fix for it though.
Posted on Feb 19, 2009
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
  • 53 Answers
SOURCE: tv not letting remote work. Have 2 remotes it is the TV. Philips
what you have is a bad IR sensor board. The part # is:
313926859182. Right now, there are so many of these things failing, that finding the original might be difficult.
Don't fear, though; it's a small part. And, best of all, it's cheap. Expect to pay around $5.00 for the part, maybe a bit more, maybe less, depending on the supplier.
Now, if you are handy with a power drill (fitted with an octagon/star bit for the back of your set), you can remove the 20 or so star-bit screws from the back of your television. Don't worry about putting the set on the floor. If your TV is on a stand, simply turn it around. You'll need to remove the stand screws, but you won't need to take the TV off of the stand.
Now that you've taken the screws out and removed the back cover, look in the lower left hand area of your set. You'll see a 4 inch long circuit board with 2 cables running to it. Pull the cables out (they'll come out easy). Remove the 2 star-bit screws.
One of the board's sides is under a plastic tab. Lift the board out of its slot from the other side.
Put your new board in, reconnect the two cables, reassemble the back and you are set to go.
Expensive repair for a few bucks and a better IR sensor.
Posted on Aug 02, 2009
My HP Elitebook 6930p wi-fi connection stopped working
It sounds like windows update may have changed your driver to a generic one. Download and install the driver again from the HP link for your model laptop here HP EliteBook 6930p Notebook PC
Oct 17, 2015 | HP EliteBook 6930p Notebook PC
6930 black screen
Try connecting it to an external monitor if possible.
You can use the VGA connector on your laptop to connect it to the Monitor.
restart the laptop and see if it comes up on the external monitor.
If it does show on the external monitor, It's probably the laptop screen going bad. and they ain't cheap. here's a link to a screen on Amazon, just to give you an idea...
Amazon com HP EliteBook 6930p Laptop Screen 14 1 LCD CCFL WXGA 1280x800...
If it still doesn't show, Hold down the function key and press the CRT/LCD button (Usually F8) to see if you can cycle between the external and the laptop monitor..
Hope this helps
Apr 16, 2014 | HP EliteBook 6930p Notebook PC
Does the vga card have a tv out capability
Yes it does, you will need a VGA cable running from the laptop to the TV...Assuming your TV also has a VGA connection.
if you TV does not you can use an adapter.
23815067-xdyygz2jnmsnxs0f22zxdtmj-4-0.jpg Hope this helps,
Thanks and please rate:)
Gary
Mar 13, 2014 | HP EliteBook 6930p Notebook PC
HP Elitebook 6930p display lock repair
http://forum.notebookreview.com/hp-business-class-notebooks/548922-hp-elitebook-6930p-display-lock-repair-how.html
Dec 29, 2013 | HP EliteBook 6930p Notebook PC
Fit my HP EliteBook 6930p?
accu HP EliteBook 6930p 100 percent compatible with you HP EliteBook 6930p. I bought two Compaq Presario CQ61 batteries from http://www.accukorting.com/hp-elitebook-6930p.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Nov 30, 2012 | Computers & Internet
Hi ,i have a user is using hp elitebook6930P fn043ut,but unfortunatly he lost his own adapter, and now he is in china,so the question is any problem that machine connect with other 6930p series adapter?
Hi timilang...
Just have your friend pick up a compatible adapter over there it will work just fine...just make sure it is the same output and has the same connection for your elitebook.
Please take time to rate me
Sep 05, 2011 | HEWLETT-PACKARD EliteBook 6930p (FN043UT)...
Cannot connect to the projector using EliteBook 6930p
Get the latest driver and re-install again. Download it from its website.
Aug 16, 2010 | HP EliteBook 6930p Notebook PC
Philips 42PFL3403 42 in. TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
