Question about Toshiba 42H81 42" Rear Projection Television
Verticle wavy lines, worse when cold - Toshiba 42H81 42" Rear Projection Television
    President:
  • 1,099 Answers
This is a vertical deflection problem - possibly a bad capacitor, bad connection, flyback/pumpup diode, or other component. None of these should be very expensive (in a relative sort of way).
If the symptoms change - particularly if they become less severe - as the set warms up, a dried up electrolytic capacitor is most likely. If they get worse, it could be a bad semiconductor. Freeze spray or a heat gun may be useful in identifying the defective component.
It is often easiest to substitute a good capacitor for each electrolytic in the vertical output circuit. Look for bad connections (particularly to the deflection ports), then consider replacing the vertical output IC or transistor(s).
A missing power supply voltage, defective vertical output IC, or a component associated with it is likely bad. A bad connection or blown fusable resistor may be the cause of a missing power supply voltage.
The following are NOT possible: CRT, flyback (except possibly where it's the source for a missing voltage but this is more likely just a bad solder connection at a flyback pin), tuner where the controller is at fault - see the sections on these specific brands. I am just trying to think of really expensive parts that cannot possibly be at fault.
Hope this will help..
Posted on May 26, 2010
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Jumping lines throughout the screen affecting quality of picture
You didn't say weather the lines are verticle or horizontal, but if the lines are verticle check the circuit for a weak capacitor or if the lines are check the horizontal circuit for a weak capacitor. During your check check for cold solder joints, idf you come across ant re-solder then. Good luck.
Jan 27, 2011 | Pioneer PRO-520HD 53" Rear Projection...
Samsung 50 HLN5065WX has wavy lines on analog input
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Jul 16, 2010 | Samsung SP50L6HX 50" DLP HDTV
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
I don't know what the light that came on means.
That light indicates you are low on coolant. Make sure the engine is completly cold and remove your radiator cap, fill to top with new coolant, also fill reserve bottle to cold line.
Hope this helps
Jul 07, 2008 | 2004 Pontiac Sunfire
Black line in screan
Hi sony with line is a verticle ic la7838 is one of the verticle ics that go in some sony . or cold solder joints on ic if you tap it and picture come back
thanks DOCTOR VIDEO.
Apr 27, 2008 | Televison & Video
Picture Jumps/flashes for first 5 minutes
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Nov 16, 2007 | Toshiba 57H81 57" Rear Projection...
Monitor settings
try to adjust with the panel button . bye
Sep 23, 2007 | HP Compaq FS7600 17" CRT Monitor
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Toshiba 42H81 42" Rear Projection Television Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
