I have a whirlpool washer. Model GVW9959KQ2. In the wash cycle, it jumps from 20 minutes to 4 minutes. I have replaced the main board, the rps sensor and the lid swith. None of these have fixed the problem
  • Washing Mach... Master
  • 19,396 Answers
Hi.
The problem is either a faulty pressure switch or a defective timer board. The first one is a more common fault.
The pressure switch senses the level of water remaining in the tub. By closing and opening the switch determines the advancement of the timer board.
If the washer skips fill, drain or agitate, then the problem is likely the pressure switch.
Sometimes the switch can be superficially tested or even fixed by blowing inside the rubber tube attached to the switch.
A full test on the switch is performed reading Ohms at switch's terminal while blowing into the hose.
If the water level switch is OK, then the faulty part is the timer control.
The water level is part 8 in diagram below:
Here parts:CONTROL PANEL
If you want to contact a technician call the number listed on the owners manual.
Posted on May 26, 2010
Whirlpool Cabrio model WTW7300X washing machine
Did you inspect the area around the drum? You have to take the top off to do that. Then there is a water sensor on the left side. The error that you get is from the drum speed sensor.
Dec 16, 2013 | Whirlpool WTW7300X Top Load Washer
Will not spin code 51
Hello there and thank you for choosing fixya
This is the Cabrio washer. F51 fault code is likely the Rotor Position switch failure, located on the motor. Even though it might run, the Hall sensor inside it has gone out. The Cabrio manual is in the Online Repair manuals Forum which you may jump to from any page at the bottom right if you want to test motor resistance from the convenience of the console. Many people mistakenly replace the main control board in hopes of correcting this issue but it is actually a communications error between the Hall sensor and the main board.
There is a Rotor Position switch kit which should correct the problem, and comes with a new harness and excellent instructions. picure below :
Jan 26, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washing machine wont finish spin cycle and comes up with a code blinking F 51. how do i fix this problem I cant finish one load of laundry, without this cod F 51 poping up. thank you wendy
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Code f50
It has a faulty control board. sorry but this a bad part from the factory. There is class action lawsuit against whirlpool about it. Call and complain and then maybe they will pay to fix it.
Nov 18, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio whirlpool washer
you could clean the rps sensor with rubbing alcohol. tip machine back, remove the rotor with al allen wrench. remove the (4) 5/16" bolts holding the stator on, carefully unclip the rps sensor. (Rotor Position Sensor). Remove the wire clip and clean the contacts. Reassemble and give it a try. Or have your dealer ( unless its sears as they WILL NOT help you, call yourself, 800-253-1301) and see if they will give you a one time goodwill gesture to their customer and cover it under warranty. If cleaning doesn't help you need the control board, wire harness, and rps sensor replaced. the rps sensor should come with the new harness. Whirlpool may cover parts????? hope this helps
Aug 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Code 51
Saw this in other area of blog (see below). I had same problem and Whirlpool service replaced RPS control board...fixed problem. Best Solution posted on Oct 20, 2007 2%20stars.png
446a518.jpg By wizard_s.gif eagle338
Rank: Wiz
Rating: 75%, 482 votes
there is a motor rotor position sensor(RPS) failure.
Refer page 10 of the manual below
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
If you still cant fix it come back here..and ask i will help you out..
And please dont forget to rate if its solved..
Aug 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
