Question about Whirlpool LER4634J Electric Dryer
A sponge fell into the vent of my dryer. How do I get it out. Is it safe to run the dryer with the sponge in the vent hose?
  • KEN LaPOINT
    KEN LaPOINT May 26, 2010
    First of all, if you're talking about the exhaust vent duct, your dryer will run with a sponge in the duct, the sponge may affect the performance, but you may be able to blow the sponge out of the duct by running the machine. You may need to take the end cover off the vent, or the ducting loose from the end vent, but you should be able to blow it all the way to the end of the duct for easier access.
    Novelist:
  • 77 Answers
If the sponge fell down inside where your lint filter goes, that could be a problem. It is entirely possible that the sponge was blown out of the machine and there is no problem at all. But, if you cannot retrieve it with a clothes hanger or anything like that, you will have to take the dryer apart. So yes, the sponge could cause a clog and clogs are bad. The hot air must be able to get out of the dryer and blown outside with the least resistance possible.
Taking the dryer apart. UNPLUG the dryer from the wall. Pull the dryer away and get behind. Remove the dryer vent and back panel (8 1/4 inch screws). On the left is the lint chute where the sponge could possibly be. Simply remove the 4-6 1/4 screws and take the chute out. Look inside for the obstruction :) If it is nowhere to be found, it made it out of the dryer. Check the vent behind the dryer and the exit of the house. If it is nowhere to be found it could be inside the vent going to the outside of your house. The vent needs to be cleaned at that point to get the sponge out.
Posted on May 29, 2010
I have a Maytag Bravos dryer. When I emptied the lint trap part of what was on it fell off and now my dryer won't run. I have cleared the vent and hose
When you say part of what was on it fell off was this lint or a piece of the dryer? If the switch on the door has broken the dryer will not run. In this case you will need to replace the switch / lever.
Nov 17, 2014 | Maytag Bravos 6.8 cu. ft. Electric Dryer -...
While drying water puddles from underneath the dryer and also drips from the control knobs.
If your dryer is leaking water, then you have a serious clog in the exhaust vent ducting somewhere. The water comes from condensation inside the dryer exhaust. As your clothes dry, warm moist air is exhausted out the dryer exhaust vent ducting. If you have any kinks, excessive bends, sags, or excessively long ducting runs, they can create choke points for lint to accumulate. Once the lint accumulates, it begins to collect moisture. As it collects moisture, it will act as a sponge and collect more lint until the dryer becomes completely clogged. Left in a clogged state, the dryer begins to overheat and dries less efficiently. You may notice longer dry times or an excessively hot dryer. Eventually the dryer heating circuits will fail. This can also become a fire hazard if the lint becoimes so backed up that it begins to collect on, or near, the heating element.
If you have not checked the dryer ventilation any time recently, now may be a good time to do so. I recommend checking it about once per season to ensure it is not obstructed. Make sure you are also using the semi-rigid metal type ducting. It resists crushing, kinking, resists heat better, and resists rodent infestation.
NOTE: Mice are notorious for building nests inside dryers. Give them a warm place with bedding material and they will make it a home.
Make sure the exhaust vent is at least 12 inches off the ground. This will deter mice and others pests (like snakes or birds) from entering the dryer exhaust from the outside. If you place a cover on the vent, make sure it is of the louvered variety. Do not use screens. They will collect lint and clog easily.
An easy test to determine if you have an exhaust problem is to remove the dryer vent hose from the back of the dryer. Turn the dryer on and allow it to run. The air leaving the back of the dryer should be forceful and warm. If the air flow is weak, you need to check the dryer interior. If the air flow is normal, reattach hose and run the dryer again. This time, check the exhaust vent where it exits your home. Again, the air flow should be forceful and warm. If not, you have a clog somewhere in the ventilation ducting which will require cleaning.
NOTE: If you are using plactic ducting, get rid of it. It collapses easy, rips and mice will chew right through it.
In addtion, many home owners unknowingly will push the dryer against the wall and crush the hose behind it. This will also clog the vent and make the dryer inefficient. Leave about a 1 foot space behind the dryer for proper ventilation and ensure the vent hose does not get crushed. Semi-rigid hose will prevent this from happening.
If you have any questions, please let me know. I have seen this problem many times. Let me know what you find and if I can be of further assistance. I hope this helps you.
Dec 30, 2009 | Kenmore 700 6972 Dryer
I have a Kenmore Elite DRYER that leaks water???? Whats up with this? How do I solve it? Thanks
If your electric dryer is leaking water, then you have a clog somewhere in the exhaust vent ducting somewhere. The water comes from condensation inside the dryer exhaust. As your clothes dry, warm moist air is exhausted out the dryer exhaust vent ducting. If you have any kinks, excessive bends, sags, or excessively long ducting runs, the can create choke points for lint to accumulate. Once the lint accumulates, it begins to collect moisture. As it collects moisture, it will act as a sponge and collect more lint until the dryer becomes completely clogged. Left in a clogged state, the dryer begins to overheat and dries less efficiently. You may notice longer dry times or an excessively hot dryer. Eventually the dryer heating circuits will fail. This can also become a fire hazard if the lint becoimes so backed up that it begins to collect on, or near, the heating element.
Oct 27, 2009 | Dryers
Hello, A small piece of sponge fell in to the Lint Filter hole. How do I remove it ? would it cause any problem ? Thanks
if small enough to to get pass filter if u can see it use tape on stick and remove if not remove back vent line and vacuum around exhaust than turn on, air [no heat] dry, sponge and any thing else will blow out reconnect ur done
Oct 05, 2009 | Hotpoint Dryers
Sock fell down lint vent and daughter turned on dryer
Turn off you power to the dryer and then,
You could run a coat hanger straightened out with a hook bent on the end of it into the lint vent at try to hook the sock.
But probably you will have to remove the back to follow the lint vent.
You may try to remove the vent hose and run the straightened coat hanger in there to try and remove the sock.
Hope this helps
Sep 30, 2009 | Whirlpool LEQ8000JQ Electric Dryer
No heat when drying
Are you doubly-sure the air vent didn't fall off because the hose was clogged?
Mar 16, 2009 | Kenmore 63942 Dryer
Water in vent
your vent out the house is broke or fell off,,suspose to a flap or lilltle blind type,,the cold air is coming in whule the hot air is trying to get out and it condensates in the vent hose ,,replace out side vent..with new vent kit..the best by is window ehaust kit...onthejob
Jan 10, 2009 | Kenmore 82822 Electric Dryer
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Estate dryer with lint trap on top- a bottle fell down in the hole- how get OUT?
Go to www.repairclinic.com and enter dryer model. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Estate video showing disassembly. The dryer should not be operated with the vent blocked.
Oct 06, 2017 | Dryers
Cleaned vent hose, dryer still taking forever to dry clothes.
you have a family of squirrels living in the rest of the vent tube which is leading outside...check vent outside. I once had flying squirrels come into my house through the dryer vent! My dog had a kitten.
Jun 04, 2007 | Whirlpool GCEM2990LQ Electric Commercial...
Whirlpool LER4634J Electric Dryer Logo
244 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
