Question about Microsoft Windows 2000 Professional for PC
When i start my com it comes up with blue screen and says system32 error could not load driver wot do i do??i hav no boot disc,,can i fix it without???and how??
  • RescueTechLA
    RescueTechLA May 26, 2010
    What's the EXACT message?
  • 180 Answers
Its easiest to repair with a boot disc but if you dont have you will just have to borrow one. then you can change your os from windows 2000 to any modern ones from xp you have to first boot from the cd and then format the drive and reinstall the windows, i dont think its possible without the boot disk
Posted on May 26, 2010
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Dell optiplex 780 i wanted to change from windows 7 to xp blue screen appears how to fix
You are going to need to start your computer in safe mode and find the XP drivers that will work for your motherboard manually from the web (Assuming that there are any created for XP for that board). That blue screen you keep getting is because you don't have the correct driver loaded for something on the motherboard that it needs to boot correctly and your XP install couldn't find it on the web to install automatically.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking".
Now start looking for your drivers here:
http://www.dell.com/support/drivers/us/en/19/Product/optiplex-780
Aug 17, 2012 | Dell Computers & Internet
Imedia system32 error
okay this is a confusing post/question. you can always start a machine from bio regardless of what operating system you're running. if you're attempting to boot from the disc, tap f12 @ boot until you get a one time boot menu and choose the dvd/cd drive. that should load the setup file. the windows disc does not load setup onto the hard drive. if you're running xp when you have the option hit 'r' to repair the computer, when you get into command prompt type sfc /scannow. this will search and fix all system files. you can also try chkdsk c: /r this will fix any errors in the file structure. good luck
Jan 30, 2012 | Packard Bell iMedia Computers & Internet
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
I have an eMachine T3410. When it boots, a screen
your missing the biosinfo.inf. try reinstalling the system but backup everything you need first.
Jun 09, 2009 | E-Machines eMonster 600 PC Desktop
IBM server dc can't boot due to system32\drivers\pci.sys missing
You mention on boot that the server shows a logical drive of 158GB, which obviously means the server is detecting the drives ok.
Quite often Windows doesn't have the correct drivers to support systems using RAID controllers such as IBM ServerRaid, so this is probably why the setup CD states "No HDD detected, press F3 to reboot". When the Windows Setup CD Boots, it should at some point (on the blue screen) at the bottom of the screen state something like "Press F6 to load additional drivers". If you can get the correct drivers from IBM website, and load them by pressing F6, Windows should be able to see the drives ok. Hopefully it will then be able to successfully repair the error.
May 23, 2009 | IBM eServer xSeries? 206m
Acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Dec 23, 2008 | Acer Aspire 5100 Notebook
Toshiba laptop problem
boot your laptop from a xp cd and select repair option
Sep 30, 2008 | Toshiba Satellite A105 Notebook
Microsoft Windows 2000 Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
