Question about Yard Machines 155 Torque Briggs Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000
Model - 21a-340-120 serial #1j139k50105 mtd rototiller carb #214706t-p2 3648 1589, has a spark,has gas to carb, but spark plug is dry? it will start if starting fluid is sprayed directly to carb, but only will run for afew seconds.[ carb has been cleaned, their is no adjustment screws.
4 Suggested Answers
  • 33 Answers
SOURCE: I can't start my
The carburetor jets are plugged. Complete disassembly & soaking in carburetor cleaner then re install parts after rinsing off & drying them. Make sure all ports are open. Torch tip cleaner is helpful.
Posted on Sep 10, 2009
damnor01
  • 1179 Answers
SOURCE: I have a Yard Machines
Air is not getting into the engine, clean the air filter. Or it may be due to a fuel blockage in the pipe. I would clean the air filter and the carberator.
First try just the air filter, you may just get away with it ey! Won't be too much work.
Take care!
damnor01
Posted on May 29, 2011
kel1guy2002
  • 3740 Answers
SOURCE: My mtd(11A-54MC552) lawnmower won't start. changed:
The Flywheel has a brake and switch assembly on that is item 8 of this link: http://www.ereplacementparts.com/mtd-11a54mc006-2009-push-walkbehind-mower-parts-c-20039_20100_133234_21459.html#part_343018
The switch is made or unmade by the position of the user safety bar on the handle. When the cable between the handle and the flywheel safety brake wears or needs adjustment the safety switch continually grounds the ignition so there is no spark. You may have to adjust the user safety bar cable at the engine flywheel brake switch area by losending the mount screw and moving the cable jacket further away from the switch. Then re-tighten the mounting screw.
If this is the first start of the season you may have to remove the carb float bowl as shown on the bottom of item 14 the above link to clean out the jet orifice in the threaded area of the carb. Make sure you remove all debris in the carb float bowl area. You should also have fuel flow anytime the float is positioned below horizontal.
If none of the above corrects the problem respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Posted on Jun 10, 2011
I got a Honda mantis rototiller,gx25 model 4 stroke,its got a new carb../ plug / gas / oil / fuel filter / ignition switch, its getting gas to carb/ getting spark but it wont start up .....help me..
If you have proper timing, compression, gas and a spark, the engine should fire/run.
Have you tried a spritz of starter fluid to see if it fires ?
The flywheel could have sheared the key and affected timing.
About the last thing I can think of is valve adjustment, specifically the intake valve, although I think it would be difficult to pull the crank rope if that's the problem.
Feb 13, 2018 | Honda Garden
MTD lawn mower won't stay running.
Did you empty the carb bowl and clean out any old fuel & contaminants? This is the most effective way to determine fuel issues. It also gives you the opportunity to remove all old fuel from the fuel lines, filter, & drain the tank bone dry. You may have already introduced water from your previous efforts so take out the plug & pull the cord a few times to dry out the cylinder. Next start the first time with starter fluid since you may still have contaminants in the primer system. In the future use only non-ethanol fuel, a marine grade stabilizer such as "Sea Foam" and replace all fuel every spring. Fuel begins to varnish and break down after 1 month unless stabilizer is used. Ethanol gas absorb water from the surrounding air in about 2 months & only gets worse.
Sep 06, 2015 | Mtd Garden
I inherited an MTD front tine 5hp rotto-tilleran woner. I have no idea about model number. I have not yet found an owner's manual, operation guide, etc. There is no model or serial number anywhere. ...
What to remember when working on these gas engines you have to have fuel spark and air usually on these small engines there is a screen in the bottom of the gas tank that gets clogged up check out the spark plug and take the air filter off and wash it in warm water with dawn dish detergent let squeeze all the water out of the filter and let it dry out a day or so hope this helps Merry Christmas
Dec 09, 2017 | Mtd Garden Tiller (Mtd)
Handle on pull cord came off and cord went inside,
pull spark plug then pull cord see if fluid comrs out.if so check oil level,if over full see if it smells like gas if so you have a bad float in carb or dirt stuck in needle and seat in carb if all is good could have sheered flywheel key or if over head valve engine(has valve cover) valves may need to be adj or compression release mechanism in side engine broke. todays engines have very high compression and will not turn over without release. hupe this helpl
Aug 01, 2010 | Mtd Products Yard Machines 158CC Tiller
Where is the fuel pump on yardmachine rototiller Model # OHH60
THERE IS NONE ITS A GRAVITY FED CARB, THE CARB NEEDS TO BE CLEANED. IF YOU DO IT YOUR SELF TAKE PICTURES SO YOU CAN REASSEMBLE IT !! THE FLOAT IS STUCK. THATS WHY YOU ARE NOT GETTING GAS.. IF'N I WAS OF HELP PLEASE VOTE..JAY
May 25, 2010 | Yard Machines Tecumseh 148cc Front Tine...
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Apr 13, 2009 | Mtd Garden
We have a mtd yard machine roto tiller model 21A-340-06295208
i need a part list for a tiller model 21a
Mar 28, 2009 | Mtd Garden
Yard Machines 155 Torque Briggs  Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000 Logo
336 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
