Question about Minolta Maxxum 400si 35mm SLR Camera
I have a minolta maxxum 400si .ive tried putting it in manual mode for my new manual focus lens the m is on my display screen.should be in m mode i think?also when i look into viewfinder i see 125 on left it states in my manule 250 should appear.i still cant get camera to click ,(take pics.)it works fine w/auto lens.my battery is now blinking as well.how do i make this camera take pics.in manual mode using my telephoto lens?
  • 10,865 Answers
Hello. Turn the camera on and go into the menu. Find the reset function and reset the camera. This will take it all back to the factory settings. NOW do the things you need to do and you should be fine. IF not, you have an internal issue which you should take into the camera shop so as not to void any warranty. Joe
Posted on Jun 11, 2010
How to put camera in automatic focus
The af/manual switch is located on the side of the mirror box. However, this model was notorious for failure of the auto focus motor. Also check the lens to make sure the focus moves smoothly (take off camera)
Jan 18, 2014 | Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 400si is locked up
link to your manual, it tells us that we have a winding motor problem, I would do as you have done, so I would ensure that batterys are in great shape, the only other thing I could suggest is to try to turn the winding motor by hand in case it is just locked up. Failing that I presume the motor has died and needs replacement.
Dec 05, 2007 | Minolta Maxxum 400si 35mm SLR Camera
Cant find the batteries for the cam
It uses a 2CR5 battery, which should be available at most electronics or office-supply stores. An online source is at http://www.batteriesplus.com/product/31018-RAYRL2CR5--1-Lithium-Battery/563-0/4739-Film-Camera-Battery/56279-Minolta/Maxxum-400si.aspx
It has a Minolta A-mount lens. Any of the newer Minolta (and some Sony) lenses may be used. The older Minolta lenses for the SRT-series cannot be used.
Nov 26, 2013 | Minolta Maxxum 400si 35mm SLR Camera
My tilt/shift lens isn't working with my Minolta Maxxum 400si - the aperture which is controlled through the lens won't communicate with the body, is there a way around this?
Is this an auto focus lens? Most shift lenses are manual focus. Also, because they shift, they can generally only be used on manual not he auto settings. If the contacts are not on the back of the lens then it will on communicate with the body
Sep 15, 2013 | Minolta Maxxum 400si 35mm SLR Camera
What is the size of the lens for this camera?
The Maxxum 400si is an interchangeable lens camera, so there is no single lens for it.
If you're asking about the mount, it uses the Minolta A-mount so all such lenses, including current Sony-mount lenses, will fit on it.
If you're asking about the lens focal length, Minolta has made lenses ranging from 16mm to 600mm. These lenses vary widely in size (and weight and cost). The filter size also varies from lens to lens.
Or were you asking about something else?
Feb 18, 2011 | Minolta Maxxum 400si 35mm SLR Camera
Is it possible to manually control the shutter speed, aperture, AND the focus on the Konica Minolta Maxxum 400si SLR 35mm film camera? I need to be able to manually control these features for a film class...
Yes. You have full control over the shutter speed and aperture in the Manual exposure mode, as described in the "M Mode: Manual Exposure" section in the manual.
You also have full control over the focus, as described in the "Manual Focus" section in the manual.
If you need a manual, you can download it (in two parts) from
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Feb 07, 2011 | Minolta Maxxum 400si 35mm SLR Camera
Is it possible to manually control the focus on this camera? (Konica Minolta Maxxum 400si SLR 35mm Film Camera) I need to be able to manually control the focus, apeture, and shutter speed for a film...
The description of the manual focus is available in part 2 of the manual, page 40. The manual is available as a PDF here: http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html#si_series . It is the seventh camera in the SI series in the list.
To manually focus the lens, press the focus-mode button on the front of the camera (bottom left when you are behind the camera) until M. focus appears in the data panel. If you have an AF lens, turn the focusing ring until the subject appears sharp. If you have an xi-Series or AF Power Zoom lens, pull and turn the lens control ring.
The focus indicator will light when the subject is in focus. To return to autofocus mode, press the focus-mode button again. The camera will also return to the autofocus mode if you press the program reset button.
I hope this helps.
(in manual focus, you can take a picture even if the subject in the focus frame is not in focus. Often it means you need to take multiple pictures to get a good shot of the subject. The advantage is that you can get some interesting shots.)
Lens
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
Dec 30, 2007 | Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 7000i
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Sep 28, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 400si 35mm SLR Camera Logo
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
