Question about Home
We have a triton satellites mixer shower with remote control and sometines when i go to turn the shower on it doesn't work so i have to go in the loft and switch the mains power switch off and then on again and then the shower works. I was just wondering why it does this.
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
  • 2557 Answers
SOURCE: hi i want to replace my mains fed shower with a
I would ask at the local plumbing shop they will have all the info you need there
Posted on Apr 20, 2010
SOURCE: my new triton shower keeps dripping when switched off
The actual cause of this will depend on what type of shower unit this relates to - ie Mixer Valve, Electric Shower etc.
Generally though if the unit is new and therefore under the manufacturers warranty period the best course of action would be to contact Triton Service Dept direct - Tel 0844 980 0750 where a in warranty service visit may be arranged for you.
Posted on Jul 28, 2010
Testimonial: "thanks will do !!!!"
SOURCE: My Triton Millenium shower just
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Posted on Jan 24, 2011
Grohe mixer will only start the pump on cold. Is the unit faulty.
Ive written a solution twice but for some reason it wont let me post it.I will try to abbreviate it.
You dont say how much flow it has when the pump isnt running but I suspect there isnt enough to turn on the sensor unless all the flow is one side. ie all cold.
May 06, 2012 | Grohe Plumbing
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
Hi, I have a Triton Spellbing Shower in my Loft. It comes up with 'CS' and a 'showerhead' symbol in red on the LCD display. Do I just remove the head from the shower and clean out any limescale or is...
Yes take the head and soak it in a lime,rust,calcium cleaner, they sell one at the dollar store in a brite yellow bottle for a few dollars called awsome all purpose cleaner
Mar 07, 2011 | Home
My new triton mixer shower only runs cold water how do i get it hot
you might need to adjust the scolding setting behind the handle....
Jan 26, 2011 | Home
I have a triton dart shower which is operated by turning a flow control block. This is so hard to turn that I sometimes struggle and my family require my assistance. It is just as difficult to turn off...
I can't offer you a solution but will say that I have the same problem with my Triton Dart. I have put it down to a build up of hard water inside the valve but not sure. Think I'm going to have to contact Triton under their warranty although they do say that they will not cover faults resulting from limescale.Great
Nov 09, 2010 | Home
My new triton shower keeps dripping when switched off
Jul 27, 2010 | Home
Shower either runs cold or extremely hot
hi ya, if its a triton shower valve & only 2 years old it should have a 5 year guarantee, ring Triton & arrange a service call.
it sounds as though the filters could be blocked & more than likely the thermostat requires replacing as its more than likely scaled up?
You never mentioned where your based UK or abroad?
Kindly
Richie
Dec 15, 2008 | Home
Dec 09, 2008 | Home
Cold water suply filling up header tank in loft thru hot water suply on shower.
Oct 05, 2008 | Home
Home Logo
517 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
