Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Diagram mower deck Belt On A poulan Riding mower
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 323 Answers
SOURCE: I tipped my poulan riding mower up from the right to check belt
If you remove the plug(s) so that the oil all drains back down, and some will drain back out of the muffler, it should start. But give a at least one day, maybe two. You may still have to put new plug(s) in it after it's gone. Check the fuel filter and see if you can see oil in it.
Take off the air cleaner when you get ready to start it and spray just a little starting fluid in the carb, Don't choke it. It will run rough and smoke like crazy, but after it runs a while it should be fine. It make take a few starts before it continues to run. At first it may run just on the starting fluid, but once the plugs fire up enough to burn the oil out it should run on its own.
Be sure and check the oil and if it seems like the slightest amount of gas in it, change the oil and filter.
Let us know how it comes out!
Sirwriter
Posted on May 16, 2009
SOURCE: need to replace belt on deck of john deere riding mower
does the belt on a 42" scotts lawnmower go behind the tenisoner or in front of it?
Posted on Jul 25, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a Poulan riding mower and it has a 42
The easiest way is to find your owners manual and find the picture of the belt in there. Using the picture as a guide you can change the belt in a matter of a few minutes. Just make sure that you get the new belt under all of the belt guards or you will destroy the new belt in no time. If the pulley is flat on the running surface, it goes on the back side of the belt, if it is a "v" on the running surface, the inside of the belt goes in the "v". There may also be a routing diagram under the foot board on one side or other of the tractor. Some of the AYP units have it, some don't
Posted on Oct 31, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
How do i install my 42"deck belt on my poulan 14.5 riding moweris ther a diagram ?
Your owner's manual tells and show how. If you don't have one, go to www.managemylife.com
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
What is the diagram for steel deck installation for a poulan lawn tractor 42 " deck 14.5 hp ?
Do a search on goggle for the make model and deck size and you can see the routing diagram.
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
What is the deck drive belt length for this mower deck model# PD15538LT 38" Poulan riding mower
Your mower uses the #144200 belt by A.Y.P. This belt is 1/2" by 88.3" You must use a wrapped belt for this application. The #144200 is available through www.searspartsdirect.com and will also be readily available at your local repair shop.
Sep 10, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Jun 14, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
934 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
