Question about Daewoo Televison & Video
MODEL DAWOO DSL22V1WCD, HAVE OWNED FOR ABOUT 4 YEARS WORKED OK UP UNTILL TODAY, TUNED OFF LAST NIGHT, FINE WHENT TO TURN ON,? STAND BY LIGHT TURNS OFF THEN COMES BACK ON AGAIN, YOU CAN HEAR IT TRY TO START BUT JUST CLICKS BACK TO STAND BY, NOTHING WRONG WITH CONECTION AS MY OTHER TV HAS SAME CABLE?
  • Daewoo Master
  • 3,866 Answers
These Daewoo have power board problems, the issue here in some cases where bad capacitors in the power supply board.
Now there is no telling without opening the back of your set weather a capacitor,resistor, etc has blown out. This would need a repair shop to determine these factors. but I am going to give you some helpful tips here so you can try and check yourself. But remember its at your risk.
click this tip below this has helped many people onf fixya fix there issue themselves.
http://www.fixya.com/support/r3565137-lcd_flat_screen_common_problems
on that tip ar photo's og what a bad capacitor looks like, now not all the time will you be able to tell by a visual inspection so therefore you might need a shop in the long haul here. But at least this puts you one step forward in a fix.
Please be considerate that I am not there nor do I see the tv I am going by what you say for the cause and diagnosis. Please do click the accept button for my efforts.
Posted on May 26, 2010
I have sound but no picture
If it is an LCD model rather than an LED model like the newer TVs, it is probably the back light fluorescent tube or its inverter board. These have been the nemesis of Flat Panel TVs/Monitors since their inception. Many older computer monitors that are used heavily fail in just over 3 years. This is why most of them were only warranted that long. Repair of the board/tune is possible, but results may not be optimal. With the current price of LCD TVs today, you are better off buying a new one.
Sep 18, 2014 | Televison & Video
I have had a Hunter 52" fan with a Hunter Breeze remote that has worked perfectly for almost 4 years. Starting last night when I press the light "on" button, they flash on and off at the rate of about
Sounds like a loose wire nut to me. When you turn the light on the connection warms up and the wires will expand. When you turn it off they cool down and contract. Combine that with slight vibration from the fan over 4 years it could cause a loose connection. Just pull the trim ring down and tighten all the wire nuts. The light is usually the blue wire. Dont forget to kill the power first. If that doesnt work its probably a bad remote sensor.Inexpensive and easy to replace.
Dec 13, 2012 | Dryers
Sony KL-50W2U rear projection TV stuck in standby
Try holding down the power button until it turns off and then turn it on again.
Nov 29, 2012 | Sony KL-50W2U
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
Samsung Series 7 won't stay on, it keeps restarting on its own.
I have the exact same TV and the exact same problem, I'm afraid to shut it off,
Jul 12, 2009 | Haier Televison & Video
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Sony SXRD Projection TV
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identicle. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank me...lol...
HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
Jul 12, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Televison & Video Logo
44 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
