Question about Bernina Bernette 75
Loose Spring in Bernina Bernette 70 Bobbin House
I was cleaning the lint out of the bobbin house (is that what it's called?) on my Bernette 70 with a pipe cleaner, when it caught on a little hooked spring and unhooked it. Unfortunately, I have no idea from where it was unhooked so can't put it back. When I run the machine, the loose spring dances around like crazy and is certainly a disaster waiting to happen.
I cannot figure out where that little spring is supposed to hook and cannot find a resource anywhere to help. No technical diagrams, nothing. I did buy the service manual from sewusa.com, but unfortunately, there was nothing in there about loose springs.
Thanks.
Trifect7
  • 57 Answers
SOURCE: Bobbin thread not being picked up
This unfortunately sounds dismally like a timing problem. When a sewing machine makes a sudden mechanical stop as when a needle is bent slightly and hits the needle plate, sometimes the other machine bits revolve along further causing the needle to be introduced into the hook either to early or to late to catch the thread.
To test this, remove the thread, the needle plate and and the bobbin case. Replace the needle with a brand new one. Yes, again. Revolve the machine by hand via the balance wheel and watch closely as the needle goes into the hook region allow it to it move down and then just start to move up. If the tip of the hook is not pretty close to right behind the needle than it is more than likely a timing problem.
If the tip of the hook is behind the needle in the scarf (the slight hollow on the back of the needle) than it is not timing. Thread the machine normally like it is and watch what happens as you manually turn the machine via the balance wheel. The thread should catch and be pulled around the hook and let go.
Try this and then either you figured it out the problem or contact me again. Either way please vote. Thanks
Posted on Mar 02, 2008
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
abhishek33
  • 1239 Answers
SOURCE: Have A bernina Activa 125
hi
you ended chat session and you dint rate it please rate it....here some suggestionMost likely cause is lint in and around bobbin area. If you are using a standard top tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks....... if the top tension is loose, or in the tension spring of the bobbin case if the bottom tension is having troubles. In either case you need to remove the lint......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the top tension disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance, particularly for bobbin tension issues:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Dec 08, 2008
  • 19 Answers
SOURCE: Bernina Bernette 65 sewing machine
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
Posted on Dec 10, 2008
SOURCE: 334d Bernette Overlocker
went to local berinina shop and purchased booklet for 10.95 aus dollars
thankyou feona
Posted on Jun 15, 2009
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
Is the bobbin supposed to move on the Bernette Deco 600?
Could you please let me know how you got this resolved. I just got this same machine and I am wondering the same thing...it just stopped picking up the bobbin and I have never really looked at it before that but the bobbin does not spin as well
Jul 21, 2014 | Bernina Bernette Deco 600
How to insert bobbin in a bernette 680 sewing machine?
Try going to this link and download the manual for either the Bernette 410 or 715 and look at the directions for threading and inserting the bobbin:
Bernina may not have a manual for your particular model, but these models may be close enough that you can still use the directions for your machine.
Jul 07, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
Why won't my Bernette 65 pick up the bobbin thread
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 14, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
Spring come of in bobbin area bernette 60
Without knowing which springs are involved, I cant really help - there are a number of springs in the machine associated with the hook drive and the feed regulator, so if its not obvious where the springs are attached, your best bet is to try and get a manual for the machine.
Nov 09, 2011 | Bernina Bernette Deco 600
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Viewer states problem - but cannot correct.
Hi, if you look in the bobbincase you will see a round spring. Sometimes this gets moved and it blocks the hole the sensor reads through. Clean inside the bobbincase with a q-tip. Also clean the sensor lens on the door with a q-tip. Also try rewinding a bobbin but don't start with the thread through a hole in the bobbin.
Hope this helps.
Rick
Oct 07, 2009 | Bernina Sewing Machines
Tension problems
Hi, loops on top are signs of a loose bottom tension. There can be a number of issues. First put in a new needle. The bobbin should be in turning clockwise. This is going to take a few tries before it starts looking right. Get a tiny screw driver. There is a small screw on the bobbincase that the bobbin sets in. You will need to turn that screw 1/4 of a turn at a time until the stitches tighten up and the problem disappears.
Or its possible your not getting the thread threaded through the bottom tension spring correctly.
Dec 19, 2008 | Bernina Bernette Deco 600
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
110 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
