Question about Digital Audio GX400 MP3 Player
The On/Off button doesn't work, so I can't turn on it. When I plug into the computer, the sceen light on and the computer note "new hardware found". After the installation process, I turn off and restart. I go to My computer, I can't see it even though I heard the normal bip. When I get to WMP, the message "connect a device" appears. Can I solve this big problem ? If yes, How ? Thanks in advance.
Can't turn it on. Power digital readout doesn't work.
Mine would not turn on at all, found the contact pads for the buttons was corroded. Used an eraser and cleaned them, working good now. Of course the whole thing has to come apart to get to the contact pads.
Nov 30, 2011 | Bemis 821 000 Humidifier
I have purchase lenovo Y410 but DVD drive not working since 8 days . Kindly suggest how to resovle this issue Thanks Dinesh
I would 'slap' Windows around, and make it reinstall the drivers for the DVD optical drive.
Vista:
[Note* All clicks are Left-click unless otherwise noted]
1) Click on Start (Windows logo button)
2) Click on Control Panel
3) Click on Device Manager
4) After Device Manager loads all the way, click on the + sign to the left of -
DVD/CD-ROM drives
5) Right-click on the name of the DVD optical drive
6) Click on Uninstall
Windows will come up with a 'squawk box',
"Warning you are about to uninstall this device"
It's okay, click on OK.
Now close all windows, and go back to the desktop screen.
Restart the computer.
When Windows has fully loaded you should get a pop-up out of the system tray,
"Found new hardware device", and perhaps another one will follow,
"Found XXXX optical drive"
(XXXX being the name of the optical drive)
If this doesn't work try cleaning the laser optical eye of the DVD optical drive.
Laptop on open the DVD optical drive tray.
Turn the laptop off.
Remove ALL power to the laptop.
(AC adapter {Charger} and Battery)
Use a can of compressed air for computers.
Or use a disk cleaning device for cleaning CD/DVD optical drives. (Power plugged into the laptop)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 26, 2011 | Lenovo 3000 Y410 Laptop
The on off button on front doesn?t turn the unit off and on
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
Jul 03, 2009 | Gateway FPD2275W LCD Monitor
My computer isn't detecting my Sansa mp3 player anymore.
First, make sure the lock switch isn't engaged.
Try this: disconnect the player from the computer, turn it off, hold in the volume + (or Record) button, and reconnect the player to the computer while holding the volume + (or Record) button in. Keep holding the volume + (or Record) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start --> Control Panel-->System--> Hardware--> Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Oct 28, 2008 | SanDisk Sansa c200 MP3 Player
Sansa MP3
Very hot = not good - replace the player
For laughs, Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 11, 2008 | SanDisk Sansa m240 MP3 Player
What is wrong?
It doesn;t matter if it turns on or not - it only matters if the computer recognizes that something has been plugged in, try one more time:
May 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Help
May 01, 2008 | Creative Labs ZEN V Plus MP3 Player
ILO
Apr 08, 2008 | iLO MP3 Player
Cant get mp3 to turn on
Try holding in the volume + button and reconnecting it to your computer. Continue holding the volume + button in until the "found new hardware" wizard comes on. NOTE: if you hold the volume + in for longer than 1 minute and no hardware wizard appears, this strategy will not work with your version of Windows.
Apr 08, 2008 | Philips GoGear HDD075/17 MP3 Player
Turn
Feb 18, 2008 | SanDisk Sansa m230 MP3 Player
Digital Audio GX400  MP3 Player Logo
41 people viewed this question
Top Digital Audio Audio Players & Recorders Experts
Terry Hair
Tom Chichester
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
