Question about Yamaha AX-596 Amplifier
My Yamaha YHT-791BL amplifier goes off every time I turn it on. How can I fix it?
    President:
  • 1,099 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Its usually not a fault that you will see unless somethings burnt up. This is solid state electronics and you dont see this stuff go bad. But in the meantime try disconnecting the speakers and see if it still goes into shutdown and at the same time have a dc multimeter attached to the speaker outputs. If the unit comes on and you dont see any DC at all or very very little B+ on both speaker terminal sets then you may have a defective speaker. If you do see dc then thats why the protections comming on so you dont blow out your speakers.
Also check for cracked solder connection.
Good Luck
Posted on May 26, 2010
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
My unit turns off by itself
See if there is a Factory or Return to Default procedure in your owner's manual. If that doesn't take care of the issue, your unit has a condition known as DC Offset, meaning a damaged amplifier. For more information, please visit my website at audioserviceclinic.com. You may contact me directly through the website.
Feb 08, 2014 | Yamaha Yht-s400 Home Theater System Black
Need remote code for yamaha yhts401bl receiver
The remote (most of them in fact) have only about 50 possible codes built into them. Either research for another remote or stick with the original one for the receiver--been there and done that myself.
Apr 29, 2012 | Yamaha YHTS401BL Virtual Surround Speaker...
I have blown the protection circuit on my yamaha rx 600d amp anyone with a clue whats needed to fix?
Hi friend,when something goes wrong in the output of the amplifier the protection circuit take place to prevent further damage could cause by DC power such as speakers or other related circuits...I think in your situation either one or both output amp stage have blown,then the protection cct turned on (not blown protection circuit!?). If so you have to check all the output transistors for short cct, if shorted you must also check all the DC bias cct nearby such as small transistors,resistors...If you are not familar with amplifier it better to find a tech as all amplifiers need a very precide repair technic , If the DC BIAS were wrong , when you turn on the power it will blow straight away! All times and cost will be waisted!
GOOD LUCK!
Tan Ta
Nov 23, 2009 | Yamaha Audio Players & Recorders
Yamaha YHT-390 Home Theater System
Here is a link to your receiver, at the bottom there should be a download link, The receiver you listed isn't there but maybe the few that are there can help. Hope this will be some help!
http://www.yamaha.com/yec/products/productdetail.html?CNTID=567702&CTID=5000800&RLTID=1505&DETYP=RELATION
Apr 06, 2009 | Yamaha YHT-390 Theater System
I am looking for a manual to a Yamaha YHT-390 Home Theater System. Help! Thank you.
please download HTR-6130 for your YHT-390 manual. you may have to fill some info before you can download, please do so. let me know if there is any other thing i can do.
When I turn it on the fuse blows up.
Hi..
It will need service.
I would call the music store closest to you that sells PA gear and ask who fixes theirs.
Jan 10, 2009 | Yamaha P4500 Power Amplifier 2-Channel
Trying to install a yamaha yht-590 need help,PLEASE!!
hi... if your problem is your turntable you need a pre amp phono input.. and then patch in your amplifier
Dec 31, 2008 | Yamaha YHT-690 Theater System
How do you re-program the remote to work with the system?
Change the batteries of your yamaha YHT-150 carefully and check that there is proper connection between the two ends of batteries and metal of remote control.
Aug 10, 2007 | Yamaha YHT-150 System
Yamaha AX-596 Amplifier Logo
81 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
