Question about Hobart D300-6036 Mixer
What type of oil/ lubricant should be used for the D300
  • Hobart Expert
  • 119 Answers
Mobil XHP 220
40 OZ
Posted on Jul 20, 2010
I need to get the old oil out of my Hobart D300 and put new grease back into the head. How do I get the old oil out without turning the mixer upside down and put new grease in. How much grease does the...
Hello Chardanio,
I understand you are wanting to give you Hobart D300 an Oil change.
Here are the steps you need to follow:
1. Locate the oil plug on the buttom of the head next to the plantary and the bowl slides. It will be a bolt just like on you car.
2. Run you machine for a short time in order to get the oil warm so that it will flow out of the gear box.
3. Remove the bolt so that the oil will come out into a container.
4. Once drained you reinstall the bolt
5. Remove the top of the Head (2 screws)
6. You will locate a plate that has a few bolts holding it on. On that plate there is a little tin cap you can remove it with a little flat screwdriver. Becarfule not to damage it you will have to put it back in the hole after you fill the unit.
7. Install 70oz of 140 weight gear oil. It is also thick you may have to push it in to the unit then run the unit and check the oil sight. Add slowly as you do not want to over fill the unit.
8. Replace the cap. (if damaged you will need to order a 00-064871 from the Hobart Corp. at 1-800-446-2278 or another part company)
9. Replace the top of the Head and you are done.
Turn on the unit and us it as you have before.
If you have any other questions please post to this thread.
Thank you for using FixYa hope this helps.
Mar 03, 2011 | Hobart D300-6036 Mixer
My d300 hobart mixer is dripping oil when I am using it. How can I stop the oil from dripping out
It uses grease which breaks down over time. The transmission has to opened up and all of the old lube removed and replaced with fresh lube and the bottom seal replaced. Contact your local Hobart office. www.hobartservice.com to locate your local office.
Nov 04, 2010 | Hobart D300-6036 Mixer
What kind of oil i can used for hobart d300
Transmission uses #0 weight grease, best to get direct from Hobart (their grease is the correct weight and approved by U.S. FDA & USDA as safe for use in food equipment) but if you insist on not doing so, at least obtain an Extreme Pressure #0 grease and don't overpack the transmission, I believe it should have 35 oz. if memory serves right.
Uses a heavier grease for the planetary gear, use #2 weight. Don't need much, just a light coat on the planetary gear.
Bowl lift rails use medium weight oil, again use food grade oil supplied by Hobart.
Aug 02, 2010 | Hobart D300 Stand Mixer
I HAVE A HOBART MIXER D300 ML#11627 I NEED TO KNOW WHAT KIND OF GREASE TO USE FOR TRANSMISSION,AND WHERE CAN I GET IT
Goto hobartcorp.com,create a username and then you will be able to find out what your looking for.I know that these mixers used oil when they where new but now changed to grease.Any ? let me know as im a hobart tech a repair these often.
Nov 19, 2009 | Hobart D300 Stand Mixer
Have an old hobart 140 mixer and i want to chang oil what kind of oil do i use
you need to replace it with a "FOOD-GRADE" mineral oil or FOOD-GRADE white lithium grease, you can get this from "Lubri-Plate" at their web-site
Nov 18, 2009 | Hobart D300 Stand Mixer
Oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Aug 27, 2009 | Hobart D300 Stand Mixer
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
Transmission oil
this unit uses grease if it is leaking out the grease has broken and needs replacing
Sep 09, 2008 | Hobart D300 Stand Mixer
Transmission Grease for A120 and D300
Thanks,, great info..
I took mine all apart and the oil was just at the point of turning into grease. Nasty,, brown smelling ****.... I cleaned it all up and just used a sync 50w gear oil.. I over filled it and the extra ran out of the motor end of the gear box... It might have been about 2 table spoons too much.. Now it does not leak anymore.
Thanks again,, jaybeesee
Daniel from Penokee
Jun 13, 2008 | Hobart D300 Stand Mixer
Hobart D300-6036 Mixer Logo
113 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
