Question about Maytag Neptune MDE5500AY Electric Dryer
One of the "bars" in the interior of the dryer drum is loose
The bar is hanging down about 1/2 to 1 inch by the screws. How do I get to the screws to tighten them? How do I remove the exterior?
    President:
  • 1,554 Answers
The front panel needs to be removed before the top cover can be lifted and access the baffle screws for tightening. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
Posted on May 26, 2010
How do I tighten a chain on a mccllough mac cat 330
Loosen the bar mount nuts about 1 turn, locate the tension-er screw next to the chainsaw's bar and while holding the bar up turn the screw clockwise until the chain is properly tensioned. while still holding the bar up, tighten the bar mount nuts, test the chain for proper tension. It should not be too tight, you should be able to rotate chain by hand, nor too loose where the chain's drive link's are hanging down below the bar's groove on the bottom side.
Oct 05, 2014 | Garden
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
Change drier belt on model number 41794702300 Kenmore stackable
1. UNPLUG UNIT. 2. On the front of the unit, remove two screws from the bottom panel. Remove it and you will see two screws holding the top panel and door in place. 3. Remove the screws and gently pull up and out on the door panel, INSURE NOT TO PULL ON THE WIRES LEADING TO THE DOOR SWITCH. 4. Remove wires from door switch. MAKE SURE TO NOTE WHICH WIRES CONNECT TO WHICH TAB. 5. Set door aside and you will have complete access to drum. Remove old belt, if necessary, noting now it is around the drum and weaved through or around the tension bar below the drum. 6. Once removed, or if there is no belt, or a broken belt, put the new belt around the drum so that the slack hangs below the drum. NOTE: You will probably see a black mark around the drum where the belt has laid, about in the middle of the drum. Lay the belt on that path. 6A. Lay on your back with both hands available, raise drum slightly to get access to the belt. Take slack in belt, raise tension bar slightly out of the way, bring belt UNDER the pulley on tension bar and put it around the pulley/spindle on the motor. (This may take another hand) Slowly lower tension bar back down to make contact with belt, applying tension to belt. 7. Get the door panel and reconnect the door switch. 8. Start to put door panel in place, while slightly raising drum to fit into position, careful to the raise to high or **** drum out of position off the back rollers or cause belt to slip off. Push door panel into place and put screws in. 9. Once you've got the door secure, test the belt by reaching inside and manually turning the drum clockwise until it seems to turn easily with not bumps. This is allowing the belt to settle into place and insuring it is not going to pop off; if it does, repeat the operation. If it turns easily, move on to... 10. Replace lower panel. 11. Plug in unit and test to insure drum moves freely. If not, you may need to readjust the way the door panel fits in place with the drum, or the belt on the tension bar. 12. If you need further help, please let me know.
Good luck. It's simpler than it sounds. G
Aug 02, 2010 | Kenmore 77062 Gas Dryer
Had plug in saw 2 weeks and it dose not work /// it spins but dose not move blade just loud clicking noise
ok i assume it is an electric chain saw? chain usually gets loose and can jump off clutch sprocket . to remedy this there should be atleast one nut or bolt sometimes two nuts or bolts depending on brand and model on the side cover where bar and chain inter the clutch area remove those and cover will lift off second there is a screw that faces front next to bar should be a regular slotted screw head loosenit all the way up till bar gets loose and remove bar by pulling away from saw this will come off veryeasy and chain shoouls fit on teeth of clutch sprocket and fit back onto bar tighten screw till chain tightens up on bar then replace cover and nuts on side cover but do not tighten the with one hand put tension on chain by pulling down on it while tightening screw till chain feels elastic snapping back to bar then toghten up nuts . chain should have no more then 1/4 inch slack around bar this is the correct tension youshould maintain.
Mar 18, 2010 | Poulan Garden
One of the three bars inside the dryer drum is loose and making a loud banging sound. How do you access the drum?
You will have to open the top panel.
UN-PLUG / secure input power for the dryer
Check behind the control panel for mounting screws for the top panel to the main chassis and remove them. Then using a putty or butter knife release the two clips inside the FRONT of the top panel about 3 inches from the corners by pressing FIRMLY against EACH clip and lifting EACH side of the top until it is free. After releasing the two clips the top should pivot up so that you have access to the drum.
Reassemble when complete and turn on power.
(Top locking clips.. just press down on the front corners.. if the clips don't quite clear.. depress them and push down on each corner to lock them.)
Thanks for using FixYa.
Kelly
Mar 02, 2010 | Maytag PYE2300AY Electric Dryer
How to change a dryer belt . Model number DLB1550BDLAD. What is the most effective way to put on a new belt. Any advice or tips?
Unplug unit . Check to be sure you have 240 Volts at wall outlet.
Open the door and look along the front upper edge of the dryer along the front edge. There will be 4 screws going into the top. Remove them and lift the top.
Near the floor at the front of the dryer about 1 inch in and 4 inches off the floor there will be a 5/16" hex head screw on each side that is black like the toekick. Loosen each about 3 turns but do not remove them. Leaning against the front of the dryer, Look down inside the open top dryer from above on each left and right edge there will be a 5/16" hex head screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward toy about 3 inches at the top and then lifted off the lower screws and swung away to the right from the case. Be careful not to strain any wires connected between the case and the front. Place the belt around the drum with the ribs of the belt facing the drum and hang the remainder of the belt into the lower part of the dryer.
Reverse the process of the above three paragraphs to reassemble what you have done.
Pull the dryer out enough to get behind it. there is a lower black panel to be removed by taking out all the 5/16" screws around the edge. Swing the panel aside and look into it. You will see the motor to the right and the loose part of the belt hanging somewhere in the middle.
Place the belt around the motor and idler pulley so that the ribbed side of the belt goes in the grooves on the motor pulley and the flat side runs around the idler pulley, according to the GE chart on this image.
http://www.applianceaid.com/images/belt-config.JPG
Turn the drum by hand a few times so that the belt aligns with the pulleys and is not twisted at any point.. Reinstall the rear panel again and you are finished.
Good Luck
Sep 07, 2009 | Hotpoint Dryers
There is a clunking noise -like a tennis shoe in the dryer- when i turn it on even when empty I made a mistake on the e-mail i entered rwhite26@cox.net not ewhite26@cox.net please correct and...
Press the door switch with the door open and set no-heat run. Try to locate the position of the noise. If it remains in one place, that is where you need to look inside the case. If it seems to be moving all around, release the switch and try to move the drum side to side and up and down, looking for a very loose bearing. There may be a segment of the drive belt that could be missing. Check the drum interior for loose bars fastened to the inner rim.
Aug 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a frigidare and everytime i put something in to dry the clothes get caught. the buttons or zipper . what to do
Does the drum have plastic bars spaced around the interior that may be loose? If so, the top must be removed to access the screws holding the bars to the drum. Are any of the bars damaged? If so, replace the entire set. Are any of the screws holding the drum to the center bearing loose? Tighten if so.
Jul 26, 2009 | Dryers
Tumbling bar is loose and getting looser
youll need to lift the top of the unit, and and form there youll gain acees to the outside of the drum assembly, the "tumbler bars" are secured by 5/16 screws from the outside ofthe drum assy
Feb 12, 2009 | Maytag MDG7600AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
